Results 1 to 22 of 22
Thread: Ghost vents
03-07-2016, 10:18 AM #1
Ghost vents
Hello!
Are ghost vents required in new construction. If so, then when?
Thanks in advance,
Jim Murphy
03-07-2016, 10:21 AM #2
Re: Ghost vents
03-07-2016, 10:27 AM #3
03-07-2016, 11:10 AM #4
Re: Ghost vents
They also keep the door from slamming when the HVAC is on.
But they do defeat the purpose of any soundproofing, it's like having an open window to the hallway.
03-07-2016, 11:53 AM #5
Re: Ghost vents
They are transfer ducts (better practice) or just transfer vents back to back (cheapest practice).
They equalize the pressure between conditioned space which have doors and can be closed off.
in order to put air in, air has to be allowed out.
03-07-2016, 05:03 PM #6
Re: Ghost vents
Yea colleagues, but who ya gonna call?
03-07-2016, 05:48 PM #7
03-07-2016, 08:01 PM #8
Re: Ghost vents
Jim, I hope you are not offended by my post.
I apologise profusely if you are.
In hindsight, which can be 20/20 when realized, I apologise profusely.
I meant the statement as a means of jocularity between colleagues.
Again, I hope you are not offended.
Best regards.
03-07-2016, 08:26 PM #9
Re: Ghost vents
I have never heard that term before.
03-08-2016, 12:12 AM #10
Re: Ghost vents
Jim,
To not answer your question, I have rarely seen these. The exceptions would be in manufactured homes, a few homes built in the '50s and commercial office buildings.
03-08-2016, 06:55 AM #11
Re: Ghost vents
transfer grills are as common as the folks around here
http://buildingscience.com/file/5861...token=suIytP6L
RR-0005: Transfer Grille Sizing | Building Science Corporation
for those who worry about noise transfer
many of use grew up with these at bedrooms without too much emotional scarring
03-08-2016, 11:27 AM #12
Re: Ghost vents
Barry,
Thanks for the post.
I wanted to reply pretty much the same as you and Jerry but lost my nerve thinking I might have upset Jim with my dam thoughtless Tomfoolery.
Transfers ducts.
All over the apparent building were I reside.
Stabilize pressure in a habitable environment and allow combustion air.
Hope all is well.
Best regards.
03-08-2016, 06:43 PM #13
Re: Ghost vents
Thanks to all for the replies and Tomfoolery!
Jim
- - - Updated - - -
Jim
- - - Updated - - -
Jim
- - - Updated - - -
Jim
03-09-2016, 01:53 PM #14
Re: Ghost vents
Typical construction in most of Canada is simply known as an undercut door. This is where the bottom of the door can be "undercut" somewhere between 1/2 to 1 inch above the floor line. This also allows for air and heat transfer.
Here's another POV from Building Science -http://buildingscience.com/documents/information-sheets/information-sheet-wrong-undercutting-doors
03-09-2016, 03:12 PM #15
Re: Ghost vents
Down hearyah ... south of that border ... the ICC codes require the transfer ducts/grills.
You'd probably have to undercut a door 4 inches ... and that would mean repairing the door where you cut the bottom rail out of the door.
1/2" carpet pad
1-1/2" carpet
2-1/2" undercut
________________
4-1/2" undercut
03-09-2016, 06:35 PM #16
03-10-2016, 08:59 PM #17
Re: Ghost vents
It is very common in my area to have what we call 'jump ducts'. They look like a furnace supply vent, but they 'jump' out to the hall. Sometimes the jump ducts from 3 different bedrooms come out in a single large vent/register in the hall, often located near the return air vent. I have never heard them called anything but jump ducts, but this is AZ.
Almost every manufactured home I've inspected has what I call 'transom vents' over the door to accomplish the same thing but without near as much privacy. I don't know if I made up that name or if I heard it somewhere.
If jump ducts or door trimming is needed I have a great way to demonstrate it. With the blower on I close the bedroom door almost all the way and hold a piece of surveyors tape at the opening. At a master bedroom with multiple supply vents I can get the tape waving like a flag.
I have not failed. I've just found 10,000 ways that won't work. (Thomas Edison)
03-11-2016, 03:45 AM #18
Re: Ghost vents
Claude, I did not know that. Thanks!
I do find the "air and heat transfer" statement a bit disingenuous.
I was taught heat rises. Unless they are referring to the coolest heat, or the heat with lowest over all heat performance. Or the heat not as hot as the upper heat.
The guys and gals writing this home sciences stuff might refer to the air movement as "overall air exchange." Be a safer narrative IMO.
03-11-2016, 03:58 AM #19
Re: Ghost vents
03-11-2016, 08:45 AM #20
Re: Ghost vents
Robert,
You are referring to when there is not air movement, heat will rise ... but when there is a fan blowing the air through ducts and out supply vents, the heat will go in the direction it is blown, as will cold air (which is just air with 'less heat' in it).
Trying to blow air from a furnace or air conditioner into a room is like trying to blow up a balloon - except the room will not expand, so unless there is a means to allow as much air out as is being blown in ... the room will pressurize (not much, but to the point that no more air can be blown in than is being leaked out someplace).
Undercutting doors is the old way, very inefficient and lacking (unless one likes wearing knickers, then ... it's a match ).
03-11-2016, 09:12 AM #21
Re: Ghost vents
They are called transfer grills. It's the cheap way of getting around installing cold air returns thru out the home. Builders will have a central cold air return on the 1st and 2nd floor and use transfer grills and also under cut doors in order to move air. This eliminates the need for return duct work in the basements. Around here (buffalo N.Y. area ) they use 2 flex ducts down thru a chase and hook right to cold air drop at the furnace.
03-11-2016, 09:55 AM #22
Re: Ghost vents
Jerry, home sciences is a subject I have been away from to long.
Happy Claude brought it up.
My disingenuous statement was from my view, and yes a limited one at that.
When is air not in movement? Good question, but how much air movement is enough movement?
Objects can block or redirect air movement as well.
Window Curtains play a major roll is limiting the transfer of air, heat to warm a cool an object.
In my neck of the woods, air movement and dew point condensation are misunderstood by the average home owner.
Circulation occurs with the use of a mechanical system, like forced air HVAC or air exchangers/HRV, ect...
Baseboards, ceramic wall panel heaters and hot water radiators on the other hand, and for the most part, rely on convection as a means to transfer conditioned air. Movement is restricted/limited to convection and the amount of whole house circulation. The undercuts doing less as compared to forced air.
Happy you saw so fun in my post.
More happy you are back safe wrapped in everyone's prayers.
