Results 1 to 10 of 10
Thread: Heat Pump?
    Jul 2010
    NC
    Default Heat Pump?
    Freddie Mac foreclosure with exterior heat pump, York M # YHJD42S41S7A. Thermostat had settings for only heat and cool. When heat set, a high efficiency furnace provided heat, and on cool setting, the heat pump was operational but did not produce cold air. Wondering if this was a wrong install as this was installed after foreclosure process initiated. Also, can heat pump be wired only cooling?
    Sidney Alstad
    F.I.R.E. Services
    Oct 2010
    MONTREAL QUEBEC-CANADA
    Default Re: Heat Pump?
    Sidney, sorry I do not do foreclosures.
    1: Did the serial numbers on the compressor?
    The year on manufacturing is 1979 2000 but the fourth letter, # YHJ(D)42S41S7A
    does not match the literature on Building Intelligence Center.
    Heat Pumps life expectancy is 15 years.
    Hope that helps.
    Our Motto; Putting information where you need it most, "In your hands.
    Jul 2010
    NC
    Hope that helps.
    That is the model #; Serial # W1M5191196
    Sidney Alstad
    Oct 2010
    Quote Originally Posted by sidney alstad View Post
    I would write what I observed.
    It was manufactured in Wichita November 2015.
    Sidney Alstad
    I bet in the wrong hands it can do more than that.
    Why you, asking?
    Oct 2010
    I forgot to ask, was the thermostat set to emergency heat?
    Sidney,
    A heat pump is, basically, just an air conditioning system wit a reversing valve which reverses the direction of refrigerant flow: a) cooling uses the indoor coil as the evaporator coil and the outdoor coil as the condenser coil - this transfer heat from inside to outside; b) heating uses the indoor coil as the evaporator coil and the outdoor coil as the condenser coil - this transfers heat from outside to inside.
    If the unit was wired incorrectly, the thermostat wired incorrect, an incorrect thermostat installed, etc, a heat pump could be wired to 'only heat' or 'only cool'.
    Heat pumps typically also have a back up heat strip, thus the thermostat will have an emergency heat setting which allows just the heat strip to operate.
    I may be possible to wire it so the emergency heat strip turns on when in cooling mode - which could produce nothing positive (no heating and no cooling).
    Jul 2010
    NC
    As stated in the original post, there was no emergency heat setting on the thermostat.
    Oct 2010
    I can read what you said but did not see what was there.
    Also, I am not here to get it in the neck.
    So where did you indicate there was no EM HEAT?
    Please read Jerry's answer.
    Hope that helps.
    Have a great day.
    Gees Louse.
    Oct 2010
    Sidney,
    A heat pump is, basically, just an air conditioning system wit a reversing valve which reverses the direction of refrigerant flow: .
    If you only knew how many strange looks I get when I say that.
    Knoxville, TN
    High efficiency heat, I am thinking gas heat. While there are dual fuel heat pumps, they will still have Emergency Heat setting on thermostat.
    This could be just a gas pak standard HVAC unit. Heat and Cool on thermostat.
    The fact that is wasn't getting cold air is another matter. Did compressor kick in?
Tags for this Thread
