    mike huntzinger's Avatar
    mike huntzinger Guest
    Default rats chew drain line to furnace
    Tested the furnace in this bank owned home , it was cold so left furnace on for more than 1 hour , then went into attic only to discover lots of rats had chewed through the drian line for the furnace, luckly the furnace was over the garage and was driping into the drive way area after a drain hole was put in to get rid of any extra water
    Default Re: rats chew drain line to furnace
    The out side A/C unit somebody stole all the copper lines too
    Quote Originally Posted by mike huntzinger View Post
    Mike,
    They were Rookies as they left the condensor coils.
    Most I see with cooper thief has Every Thing gone, pipes,wires,panels,water heater, heater
    pulls,fixtures,tubs on & on.
    A few have the toilets removed, I don't know What You Do with a Used Toilet?
    BUT GONE.
    They did take the service disconnect , the best stolen job I inspected was where the bank owned home had a tankless water heater removed but replumbed with the TPR valve so cold water went to the fixtures
