Results 1 to 11 of 11
Thread: Goodman Tonage
    Erwin, TN
    Default Goodman Tonage
    Do you go by the first set of numbers on the model number or the second set for tonnage 40 or 30, is this unit a 3.5 ton or a 2.5 ton unit?? Goodman SSZ140301AG. Does anyone know ??
    Apr 2013
    High Springs, Florida
    Default Re: Goodman Tonage
    SSZ140301AG
    www.1stproinspection.com
    Certified Master Inspector
    Like Us On Facebook
    https://www.facebook.com/1stproinspection/
    Erwin, TN
    Quote Originally Posted by Roy Lewis View Post
    SSZ140301AG
    Thank You
    SSZ140301AG
    Actually, I think it is SSZ140301AG ... but it means the same thing ...
    Knoxville, TN
    Its a 14 SEER and 2.5 ton unit.
    Sam, come to the East TN ASHI Chapter meeting in November. Its November 11. Its in Knoxville. You will meet a bunch of great guys, and learn a lot.
    Its a 14 SEER ...
    Jack,
    Curious as to how you know that is a 14 SEER, the two units (indoor and outdoor units) need to match to attain a given SEER rating - curious as to what I missed in the original post.
    Knoxville, TN
    I was told the first number is the SEER rating.
    Their product information is somewhat confusing as it says two things: "Up to 15 SEER", and then it says "14" in the model number indicates 14 SEER???
    Says "Up to 15 SEER" - http://www.goodmanmfg.com/products/h.../14-seer-gsz14 (which likely depends on what it is matched too ... match it to an air handler which is not rated with that condenser unit and there may be no listed SEER for it)
    From the link above, click "Product Specifications" and it goes to this, which says that "14" indicates 14 SEER (on 2nd page), and breaks down the serial model number meanings - http://www.goodmanmfg.com/pdfviewer....rsn=54b85ac0_0
    Knoxville, TN
    Lennox also puts the SEER rating on the model number just before the btu numbers. Honestly, I don't really pay that much attention to the SEER ratings while inspecting. It was just a bit of info I got from a HVAC guy.
    http://www.goodmanmfg.com/pdfviewer....rsn=ea5d55c0_0
    Look at page 2 for the nomenclature diagram.
    Goodman refers to the numbers in question on the data plate as the Seer and efficiency.
    While there are exceptions if you don't install properly matched components, that is also true of the tonnage rating. But the data plate is the starting place for the component as provided by the manufacturer, that is its design.
    Thank you Jim.
    That was my point - just because it says 14, and the manufacturer says it stands for 14 .. or some other SEER rating ... but 14 is the initial starting point - I wouldn't say that it was 14 SEER.
    Before saying or indicating that it was 14 SEER, I would put the information for both units into the website and see what it says.
    And then I still wouldn't say that it was 14 SEER, I would say 'according to this website (I forgot the name of it right now), the outside unit and inside unit combination are listed as 14 SEER'.
    Too many variables to say that it is 14 SEER.
