Results 1 to 3 of 3
    Erwin, TN
    Default Safe clearance between a gas water heater direct vent outlet and the A/C unit
    Does anyone know the codes for safe clearance distance between a water heater gas direct vent outlet and the air conditioner unit ? Thank You
    Orlando, FL
    Default Re: Safe clearance between a gas water heater direct vent outlet and the A/C unit
    Locate the appliances's installation requirements/specifications and that will state the clearances for the vent's wall terminal.
    Dom.
    Chicago
    I have never seen a required or recommended clearance between a gas vent to an AC compressor unit. There are clearance requirements from utility meters.
    Mike Lamb
    Inspection Connection, Inc.
