Results 1 to 2 of 2
Thread: What is this?
    May 2009
    New Jersey
    Default What is this?
    This device was installed on a mid efficient heating system vent connector. Why would the installer install a device with opening on a system under positive pressure?
    2019 ASHI InspectionWorld
    Default Re: What is this?
    It's a resettable limit switch. Will turn off unit if flue gasses or heat exchanger gets too hot. I would bet the unit is not under positive pressure and has a air inducer fan that starts up but the vent is under negative pressure.
    My guess again.
