    Aug 2016
    Tennessee
    Default HVAC Drain Pan Line Capped
    The drain on the pans are capped rather than piped to drain out of the house. I am presuming the presence of an overflow alarm does not negate the need for the drain.
    Default Re: HVAC Drain Pan Line Capped
    Quote Originally Posted by David Lyons View Post
    Is that switch in the auxiliary drain pan for an alarm, or does it shut the system down?
    If it shuts the system down, that is one of the options for the auxiliary drain pan.
    Aug 2016
    Tennessee
    Thank you.
    Apr 2019
    California
    I have seen float switches just sitting on the drain pans, and as long as the wiring is correct they should shut off the HVAC unit when it gets wet. So as long as the switch does its job there would be no need, and besides based on the height of the switch it may never be met if the drain line is lower.
