Results 1 to 15 of 15
Thread: return over range in kitchen
04-16-2007, 09:37 PM #1
Any idea why a return was installed over the range with another return only 3ft. away in the hall behind the kitchen wall?
04-16-2007, 09:43 PM #2
Re: return over range in kitchen
Wes,
I've seen some custom homes that had 4 or 5 returns spread out in the house.
I would think that that is a poor choice of locataions for that one.
I guess if you forget to turn on the exhause hood, the return will catch it for you if your air is on
04-17-2007, 12:07 AM #3
Looks like just a re-circulating fan at that BI micro-wave(?). If that's their answer to venting moisture and it's actually connected to the return air...then just plain dumb and unsanitary.
Although...you could probably make soup from the furnace filter about once a month! Yummy!
04-17-2007, 04:23 AM #4
At least the filter is accessible.
Try this one with reversed access for filter replacement.
2 years without a filter didn't help the evap. coils much.
badair http://www.adairinspection.com Garland, TX 75042 TREC # 4563
Commercial-Residential-Construction-EIFS-Infrared Thermography
04-17-2007, 10:06 PM #5
From the IRC.
- SECTION M1602
- - RETURN AIR- - M1602.2 Prohibited sources. Outdoor and return air for a forced-air heating or cooling system shall not be taken from the following locations:
- - - 4. A closet, bathroom, toilet room, kitchen, garage,
mechanical room, furnace room or other dwelling unit.
04-18-2007, 03:13 AM #6
I was thinking what Jerry said, besides, it's just a bad idea. Write it up.
04-18-2007, 03:50 AM #7
Thanks guys.
04-18-2007, 05:43 AM #8
Return air runs in any kitchen, bathroom are not generally done by professional HVAC guys. Who wants the smell of tonights fish dinner in the bedrooms? That is generally the reason for no RA runs in these area's, not counting dad's refreshing smells from the reading room.
04-18-2007, 11:16 AM #9
(that moisture bit about taking showers is just secondary)
04-18-2007, 02:47 PM #10
Why do you think bathroom exhaust fans are commonly referred to as "fart fans"?
04-18-2007, 06:19 PM #11
assooo grasshopper
04-18-2007, 10:01 PM #12
"assooo"
Somebody is talking bad about grasshopper...
Rich
04-19-2007, 12:04 PM #13
04-26-2007, 09:23 AM #14
The smell has nothing to do with return air ducts not permitted in kitchens, nor the filter becoming a grease trap.
The picture is self explanitory. Where do you think the smoke and flames from a grease fire on the range will immediately go? The kitchen fire quickly becomes a fully involved fire.
The Mechanical Code prohibits return air ducts within 10 feet of a cooking surface. My pesumption as to why the same language is non-existant in the Res Code is few 'kitchens' have 10 feet in any direction from the range.
04-27-2007, 09:56 AM #15
If the code stated that no RA grills in the kitchen area's only then I would agree with you, but the code states closets,bathrooms and there are very low percentages that a fire will start in these places. Another point is that if this was to stop the spread of fire then there should be a fire damper in the supply air registers in the kitchen area.
