Thread: What is this?
05-07-2008, 11:51 PM #1
05-08-2008, 12:28 AM #2
Re: What is this?
It's a "normally closed" solenoid valve. The valve opens and allows flow to the apartment's air-handler when called for by the thermostat.
No expert on this, but you are probably right about the height and the "weight" of the liquid refrigerant being a factor although it doesn't appear to be a "pressure reduction" valve. I suspect it could screw the system up if the evaporator was left "open" when the whole system wasn't running.
05-08-2008, 06:07 AM #3
Re: What is this?
From Emerson's site, it looks exactly like yours:
http://www.emersonclimate.com/flowco.../Solenoids.pdf
05-08-2008, 09:04 AM #4
Re: What is this?
The unit has it's own condensing unit on the roof, so I don't know why they would need a solenoid for the refrigerant other than because of the height issue which may effect the pressure.
05-08-2008, 03:02 PM #5
Re: What is this?
It could be a new improved version of a line trap. If you have more than (I think it's 30" roughly) of vertical run on a refrigerant line you need to install an anti-siphon trap. Most hvac guys just install a copper trap, maybe this is technology at work. Just my guess.
