Results 1 to 2 of 2
Thread: Crimped suction line?
06-16-2008, 06:42 AM #1
Saturday's inspection, I was concerned about the tight bend on the suction line of the AC.
The AC system worked so I ran the system for 15 minutes. It cooled the house and there didn't seem to be any short cycling or frost build up.
I'm curious, is this a problem?
What would be the symptoms?
Jeff Beck
Foresight Home Inspection LLC
Similar Threads:Last edited by Jeff Beck; 06-16-2008 at 07:24 AM.
06-16-2008, 08:25 AM #2
Re: Crimped suction line?
If everything was working properly, I probably wouldn't call it out. You can't tell that it is crimped anyway, because of the insulation covering it. If it were a new installation, I may investigate further, but if it is older, it has survived the test of time.
