Thread: Funnel
    Connecticut
    Default Funnel
    Anyone ever seen one of these before? ( in this location) And why do you think it's there. And no Barry, it is not a still.
    Default Re: Funnel
    Can't see nuthin'.
    Nov 2007
    Chicago
    Default Re: Funnel
    That seems to be a forced air system. So I can not see why that is there. I have seen something like that on a boiler system, where the code would not allow a direct connect to the potable water supply due to the dangerous chemicals in the boiler lines. This was before they trusted auto fill valves with a RPZ protecting against back-flow. So the system engineer basically had to keep an eye on the pressures and such and manually topped off the water as needed along with the chemicals they where using in this system.
    Default Re: Funnel
    Reminds me of a home-made central humidifier I saw once.
    Connecticut
    Default Re: Funnel
    Yeah, that's kind of what I was thinking. Not being used now. I think with the install of a new A/C system the pan or screen was removed.
    Chicago IL
    Default Re: Funnel
    It's where you pour in the air freshener after your significant other smokes up the house from making dinner.
    www.aic-chicago.com
    Default Re: Funnel
    Hope these boys don't come knocking !
    Michael Greenwalt's Avatar
    Michael Greenwalt Guest
    Default Re: Funnel
    Maybe the heating unit runs on white wine from CA.
