Results 1 to 9 of 9
Thread: raining in the furnace
09-04-2008, 01:16 PM #1
The photo doesn't do it justice. I could hear the water raining down into the furnace from the next room. Judging by the rust, this has been going on for a while! Methinks it's time for a new furnace.
09-04-2008, 01:25 PM #2
Re: raining in the furnace
John,
Your getting a bit picky.
Most people don't have a self-cleaning furnace as such. Some would be jealous.
A little soap and that should clean up really nice.
09-04-2008, 02:46 PM #3
So what is going on. Is there no cap on the flue pipe or is the condenser coil on top of the unit and overflowing down thru it?
09-04-2008, 03:20 PM #4
09-04-2008, 03:39 PM #5
09-04-2008, 03:47 PM #6
I call it a condenser coil because it is what it does. It does not evaporate anything in condenses the vapor in the air by cooling it and turning it into water and then drains it away.
When you evaporate water it turns it into vapor.
Some say tomato some say tomauto
09-04-2008, 05:13 PM #7
09-04-2008, 05:39 PM #8
The correct term is evaporator for the indoor a/c coil and condenser or condensing unit at the exterior. Refrigerant evaporates or "boils off" at the indoor coil and condenses from vapor back to liquid at the exterior condensing unit.
If it is a heat pump, all that is reversed (for heating) so indoor and outdoor coil is more understandable for me.
09-04-2008, 06:15 PM #9
As I stated in my post I was speaking of the external part of the coil and what it does. It turns the vapor in the air into water.
I know the term. I just mentioned why I call it that. The end use is what it does.
Much easier for the client to understand as well. It also fit what the problem was with the raining on the rest of the unit. Sometimes certain words just fit.
Thanks for the edumication thow
Sorry for treating you folks like clients (I do explain to them how the system works as well.)
Thanks for the help today Jim. I appreciate it. Sometimes I would leave the house with out my head if it were not attached.
