Thread: Primary drain line material
05-10-2007, 11:43 AM #1
Similar Threads:Last edited by John Stephenson; 12-25-2007 at 06:24 PM.
05-10-2007, 12:42 PM #2
Re: Primary drain line material
From what I see the pipe is well pipe. It is usually used from the pump or foot valve to the holding tank. It is water rated.
05-10-2007, 01:52 PM #3
05-10-2007, 03:19 PM #4
Looks like it might be ABS, and that fitting is likely to collect all kinds of gook and crud, causing the condensate line to back up from that point.
05-10-2007, 05:18 PM #5
I'd be more concerned with the flex gas line entering the housing. This is known to have the potential to cause a fire.
Put a protective gromet around the wall penetration or repumb to have a rigid line exit the housing where you can then make the flex line connection.
Rich
