Old 05-15-2007, 07:59 PM
Furnace vent
Old 05-15-2007, 10:53 PM
Bob Harper's Avatar
Re: Furnace vent
Appears to be B-vent hacked open. Not approved by vent mfr. and thus codes. Should have spent the few extra bucks on a draft hood connector and not ruined a section of venting.
FYI, every single furnace I see has improper clearance to the PVC drain line.
Old 05-15-2007, 10:56 PM
Thom Walker's Avatar
Re: Furnace vent
Bob,
Am I having another false memory moment or aren't evaporator coils above the heat exchangers soon to be discontinued?
- Paul Fix
Old 05-16-2007, 06:56 AM
John Stephenson John Stephenson is offline
Re: Furnace vent
Isn't it 1" clearance from b-vent to combustible or is there an exception for PVC?
Old 05-16-2007, 07:48 AM
Bob Harper's Avatar
Re: Furnace vent
Where is there any B-vent within 1 inch of that PVC?
That's single walled pipe for about one foot so it's 6". The coil mfrs put the drain right in a place where it must pass within 6" of the appliance collar. I've seen them heat stressed and leaking.
  #6 (permalink)
Old 05-16-2007, 08:19 AM
Re: Furnace vent
Single wall pipe! Duuuuuuuuuuuuuuuuuuhhhhhhhhhhhhhhhh!!!
Is it allowed to mix single wall with double wall?
  #7 (permalink)
Old 05-16-2007, 08:28 AM
Michael Thomas's Avatar
Re: Furnace vent
"Single wall pipe"
Is it?
I appears to me that there is an interior pipe visible just above the furnace casing and also an exterior pipe which is fitting over (is the male end) of the connection with the B-Vent. What did the labeling on the left side of the pipe say? I'm not saying this is right, but it appears to be more complicated than just a single-wall segment between the and the start of the B-Vent.
  #8 (permalink)
Old 05-16-2007, 06:52 PM
Bob Harper's Avatar
Re: Furnace vent
When you hack one end of B-vent off, it become single walled vent connector.
Similar Threads
Furnace vent installation Gregg Austensen Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 3 07-16-2008 08:51 PM
Bryant furnace age Brian E Kelly Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 3 05-01-2007 10:27 PM
filter on gravity furnace John Arnold Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 0 04-28-2007 12:24 PM
Rheem furnace age Paul Kondzich Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 5 04-23-2007 12:23 AM
Furnace vent Jeff Eastman Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 3 04-14-2007 08:28 PM
vB.Sponsors
Ad Management by RedTyger
