Old 05-17-2007, 11:14 AM
K Robertson's Avatar
K Robertson K Robertson is offline
Fresh Air Return
Are there any rules that prevent a fresh air return from being this close to the condensing unit? I can't find anything, but it just doesn't seem right. And what exactly does this little box that sits by on the fresh air return duct do? First time I've come across one of these. Anyone have any info on this that I can read up on?
I'd rather be catching a big ole Redfish!
Old 05-17-2007, 12:25 PM
Brian E Kelly Brian E Kelly is offline
Re: Fresh Air Return
Not sure of the clearances, but the device you are pointing to is a mechanical damper that opens on command for fresh air.
Well thats my 2 cents.
Brian Kelly
Kelly Home Inspections
Old 05-17-2007, 02:25 PM
Thanks Brian, but what gives it the command?
Old 05-17-2007, 02:50 PM
Phillip Stojanik's Avatar
Phillip Stojanik Phillip Stojanik is offline
Typically the thermostat will have built in controls that monitor the amount of fresh air being brought into the airstream. There may however be a separate controller that looks a bit like a thermostat and often installed in the attic. This type of controller is little more than a timer that opens the intake damper for some programmed number of minutes during a fan cycle.
As far as the intake location goes, there is no specific prohibition about having it that close to the condenser unit discharge but if the system is pulling in hot air discharged from the unit then that heat is being re-introduced into the living space. From an efficiency standpoint that is a poor location from which to draw fresh air.
Old 05-17-2007, 07:57 PM
Thanks Philip, I'm just going to say exactly that on the report.
"there is no specific prohibition about having it that close to the condenser unit discharge but if the system is pulling in hot air discharged from the unit then that heat is being re-introduced into the living space. From an efficiency standpoint that is a poor location from which to draw fresh air."
Hope you don't mind my plagiarizing. Thanks.
  #6 (permalink)
Old 05-17-2007, 09:12 PM
Thom Walker's Avatar
K,
"there is no specific prohibition about having it that close to the condenser unit discharge but if the system is pulling in hot air discharged from the unit then that heat is being re-introduced into the living space. From an efficiency standpoint that is a poor location from which to draw fresh air." (Phillip said so)
No plagerism.
- Paul Fix
Similar Threads
Return for repairs, Stinger Strion? Tim Moreira Tools and Equipment 5 08-29-2008 03:46 PM
Return Air David Banks Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 24 05-12-2007 05:27 AM
Exposed wood joist in return air John Tullous Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 15 05-08-2007 07:27 PM
return over range in kitchen wes owens Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 14 04-27-2007 10:56 AM
vB.Sponsors
Ad Management by RedTyger
