LinkBack (1) Thread Tools Search this Thread
  1 links from elsewhere to this Post. Click to view. #1 (permalink)
Old 05-17-2007, 05:57 PM
imported_John Smith imported_John Smith is offline
AC Primary drain vent
I have seen several of these lately with tape over the open end. Sorry I dont have a picture, but try to envision the small vertical vent pipe (~ 6" in length) next to the evaporator coil. I skimmed the IRC, but didnt see anything about it.
Old 05-17-2007, 06:57 PM
Re: AC Primary drain vent
Vent should be on opposite side of trap from AHU.
If not, it only serves as a clean out, and allows air to be sucked in or blown out, wasting energy (and, if sucking in, sucks in unfiltered air).
Old 05-18-2007, 07:09 AM
Yes, the vent is downstream of the trap. Im starting to question my understanding of this. I thought the vent was supposed to be open and not taped over or capped. I havent missed some new rule or change in physics have I?
Old 05-18-2007, 07:13 PM
Quote:
If it is downstream of the trap, it could be a vent, and would be open.
If it is upstream of the trap, it could be a cleanout access, and would be capped.
LinkBacks (?)
LinkBack to this Thread: http://www.inspectionnews.net/home_inspection/heating-ventilation-air-conditioning-hvac-home-inspection-commercial-inspection/1129-ac-primary-drain-vent.html
Posted By For Type Date
hvac: Blogs, Photos, Videos and more on Technorati This thread Refback 05-17-2007 08:00 PM
Similar Threads
Downspout drain wayne soper Roofing System: Home Inspection and Commercial Inspection 12 05-12-2007 10:02 AM
Primary drain line material John Stephenson Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 4 05-10-2007 06:18 PM
PVC drain lines Jeff Eastman Plumbing System: Home Inspection and Commercial Inspection 1 04-18-2007 07:23 AM
Secondary drain setup Jeff Gainey Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 8 04-17-2007 11:10 PM
lead drain John Arnold Plumbing System: Home Inspection and Commercial Inspection 5 04-17-2007 04:18 PM
vB.Sponsors
Ad Management by RedTyger
