Welcome to InspectionNews.
Registration is FREE!
The Cost Of Business
Old 01-24-2009, 03:26 PM
Trent Tarter's Avatar
Trent Tarter Trent Tarter is offline
Heat Pump Question
The outdoor heat pump unit was not running and would not respond. Outside temperatures were 26 degrees. The unit was heating the home with the air handler heat strips only. The thermostat was in standard heating mode not aux. heat). I know that there are many different ways to set up heat pumps such as with or without separate outdoor thermostats etc.
I am thinking that it may be set up this way for lower temperatures. Just wondering if I should refer it to an HVAC contractor.
FREA Home Inspector Insurance
Old 01-24-2009, 03:44 PM
Ron Bibler's Avatar
Ron Bibler Ron Bibler is offline
Re: Heat Pump Question
Hey Trent. I look at these system and see that a lot of the HI get that bad news call from the new owner over HVAC units. Its been my things to look and see if there are a service tag on the unit and what the MFG. info requires for service. Most of these unit have had no service from day one. So I call for service on just about every unit i inspect due to the lack of standard service. I can find something wrong with just about every unit I inspect. C.Y.A. Trent
Best
Ron
Old 01-24-2009, 04:06 PM
fritzkelly fritzkelly is offline
Most of the newer units and thermostats do have a lower temperature setting to prevent the heat pump from turning on if it is that cold. It is usually hard to access unless you have the secret code for that thermostat and probably isn't something you want to be messing with anyway.
You are screwed either way, if you call it out as in need of repair you may be paying for an unneeded service call. If you don't, you may be paying for repairs.
I'm lucky, it doesn't get that cold here.
Old 01-24-2009, 04:57 PM
Bruce King Bruce King is offline
It's broke if the outside unit is not running in regular heat mode.
If the unit can not keep up due to temperature or user settings it will still run at the same time as the electric strips.
The only special thermostat settings I have heard about keep the electric strips off as desired and also can keep the cooling mode off if colder than 55 outside (Bryant/Carrier) but no hidden or user settings keep the compressor off in regular heat mode. Aux/Emerg mode is the only thing that would normally do that.
Old 01-24-2009, 05:13 PM
Quote:
You are right, I guess I had that backwards!
  #6 (permalink)
Old 01-25-2009, 01:41 PM
Jerry Peck's Avatar
Quote:
I've never yet seen an "unneeded" service call.
It's all in how you write it up.
Blah, blah, blah, including blah, blah, blah, have repaired or replaced as necessary blah, blah, blah.
Surely ... there was more than just 'that one thing' which "needed service", right?
Thus the service call was "needed" and I'm not paying for it.
  #7 (permalink)
Old 02-24-2009, 06:00 AM
Ben Go Ben Go is offline
I think your outdoor heat pump needs some heat pump setting... try to read more here about heat pump.. http://www.google.com/url?sa=t&sourc...B Ip2qzsPauSw ... hope this help you a little guys...
_________________
Programmable Thermostats
  #8 (permalink)
Old 02-24-2009, 07:20 AM
Nick Ostrowski Nick Ostrowski is offline
Quote:
Best
Ron
What Ron said. Most of the time, I too don't need to look very hard to find something to call out on any HVAC system.
I have yet to have anybody call me back and ask me to pay for a service call that I recommended based on my inspection findings. I figure this is because one of two things: I'm right OR the buyers just ignored my recommendation and took a credit from the sellers instead .
  #9 (permalink)
Old 02-25-2009, 06:56 AM
Raymond Wand Raymond Wand is offline
Trent,
I think your initial reasoning is correct. The heat pump cannot take enough heat out of the air to remain efficient. Thus the electric resistance kicks in to make up for the deficit.
The value of experience is not in seeing much, but in seeing wisely. - Sir William Osler 1905
Help Support InspectionNews
Similar Threads
Heat pump freeze-up Grant Harrod Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 17 01-22-2009 09:25 AM
heat pump age Dennis R Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 8 12-19-2008 04:23 PM
TXV valve mean it's a heat pump ? Gene South Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 4 05-13-2008 09:33 AM
Heat Pump Question Eric Shuman Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 7 02-23-2008 08:27 AM
Heat Pump? David Banks Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 15 05-06-2007 01:04 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
vB.Sponsors
Ad Management by RedTyger
