Old 05-06-2009, 08:10 PM
Jim Robinson's Avatar
Jim Robinson Jim Robinson is offline
Blown Cellulose over fiberglass
A friend called to ask what I thought about adding blown cellulose on top of his existing fiberglass insulation. I didn't really know what to tell him, so I thought I would post it here. Does anyone have experience or know if this creates any problems, or if it is recommended to pull out the original fiberglass?
United Infrared
Old 05-06-2009, 08:49 PM
John Dirks Jr's Avatar
John Dirks Jr John Dirks Jr is offline
Re: Blown Cellulose over fiberglass
Blown over batt is ok. Make sure that the existhing batts are installed with their vapor barrier (if they have it) towards the house side.
It's when you put batt over blown that it can be a problem. If you put batt over blown, make sure you use batts that do not have vapor backing on them. If you put batts with barriers over blown, you will trap moisture in the insulation. We all know that is not good.
John Dirks Jr - Arundel Home Inspection LLC
Maryland Home Inspection - Maryland Home Inspectors - Maryland Radon Testing - Baltimore County Rental Inspection
Old 05-06-2009, 09:43 PM
Cellulose over batt would not be as bad a over blown fiberglass. Over blown fiberglass the weight would compress the blorn fiber and it would no longer have the same R value.
Thinking of it, it would more than likely have at least a small adverse affect on batt.
Ted Menelly
Castle Home Inspection Services
www.inspectmycastle.com
Old 05-06-2009, 09:52 PM
Jerry Peck's Avatar
No problem putting in blown loose fill fiberglass over batt fiberglass, make sure (as John said) the facing on the original batt is down against the ceiling.
It would be better, though, to put batt over batt with the new batt being unfaced and laid perpendicular to the original batt insulation.
Old 05-06-2009, 09:56 PM
You did read cellulose, right?
Ted Menelly
  #6 (permalink)
Old 05-06-2009, 10:08 PM
Jerry Peck's Avatar
Quote:
Nope.
I would not recommend blown CELLULOSE over fiberglass (batt or blown - post did not say, I went back and checked it).
I wondered why you mentioned "cellulose" and now I know.
  #7 (permalink)
Old 05-06-2009, 10:13 PM
Nope.
You schtinking scanner you. I never do that
Ted Menelly
  #8 (permalink)
Old 05-07-2009, 06:28 AM
Jerry Peck's Avatar
Actually, sometimes I do that, but in the case above I did not, and I STILL missed it!
Jerry, YOU REALLY HAVE TO LEARN TO READ.
  #9 (permalink)
Old 05-07-2009, 07:59 AM
Is the cellulose too wet? Why not over the batts? We could do the unfaced fiberglass batts on top of the original, but blowing in would certainly make things easier. Maybe we look into blowing fiberglass in on top as well.
  #10 (permalink)
Old 05-07-2009, 08:05 AM
Not a problem with cellulose being wet, it is just much heavier and tends to settle more than fiberglass.
The weight of cellulose will compress fiberglass and thus reduce the effective R-value as well as the number of inches. Cellulose base with fiberglass over the top is no problem but cellulose on top gives less desirable results.
Blown fiberglass would be my choice. Around here I have found having it blown in is about the same price as buying the batts and doing it myself.
I have a rule, I always pay for a professional job if it is not going to save me money by doing the work myself.
I am not that fond of sweating and getting covered with itchy insulation!
Allen, Texas 75002
  #11 (permalink)
Old 05-07-2009, 08:44 AM
I hear that Jim. I just recently help my nephew out in blowing cellulose into his attic. Even though he was in the attic and I was feeding the hoper I was covered with the dusty crap. Not itchy, just dusty and the wind blowing around did not help the situatioon. He could have had someone else do it for slightly more but what the heck, isn't that what uncles are for?
Ted Menelly
  #12 (permalink)
Old 05-07-2009, 03:28 PM
That was why I was trying to stay away from the batts myself. I told him I would help, but I was planning on manning the hopper while he crawls around in the attic.
  #13 (permalink)
Old 05-07-2009, 03:32 PM
Price it total dollars per square foot and I would be surprised if it actually cost you more than $100 difference between batts material only and blown in turn-key. Maybe I'm just lazy in my old age, but I would not get out of bed without some substantial savings!
Allen, Texas 75002
IC Home Inspection Report Writing
Similar Threads
Cellulose Insulation on Dirt ??? Clint White Sub-Structure: Home Inspection and Commercial Inspection 16 04-01-2009 09:54 AM
Fiberglass insulation in the fireplace MaMa Mount Fireplaces, Chimneys and Solid Fuel Burning Appliances: Home Inspection and Commercial Inspection 9 01-19-2009 05:26 AM
Cellulose Insulation Clearance Requirements Tim Kallmer Attic Areas: Home Inspection and Commercial Inspection 9 12-25-2008 10:45 AM
vB.Sponsors
Ad Management by RedTyger
