Welcome to InspectionNews.
Registration is FREE!
The Cost Of Business
Old 07-01-2009, 05:05 PM
Gene South's Avatar
Gene South Gene South is offline
TXV Expansion valve insulation
I usually write up TXV's that are not insulated. How many of you do the same ?
Gene
Help Support InspectionNews
Old 07-01-2009, 05:36 PM
Jim Luttrall Jim Luttrall is online now
Re: TXV Expansion valve insulation
Well Gene if there is condensation, it should be insulated. Typically this will just be the outlet of the valve and of course the suction line where the bulb is attached.
Allen, Texas 75002
Old 07-01-2009, 07:14 PM
Gene South's Avatar
Jim thanks, I guess I thought the bulb should be insulated, thinking that would make the TXV more efficient. Maybe I am wrong.
Old 07-01-2009, 07:34 PM
The bulb is just a temperature sensor clamped to the tail of the evaporator coil. The portion of the suction line exposed outside the cabinet (not the usual method) should be insulated to prevent condensation. If you are not getting a good thermal bond, the valve could malfunction and over or under feed the coil which would effect the operation and overall unit efficiency. Insulation would be a good thing at the bulb in that respect.
Allen, Texas 75002
Old 07-01-2009, 07:54 PM
Dan Hagman's Avatar
Dan Hagman Dan Hagman is offline
Hey Gene Jim is correct, the expansion valve bulb needs to be insulated because it is operating the valve to maintain the superheat of the evaporator. Normally the TXV valve itself is not insulated, but the suction line after the valve needs to be. Some TXV valves are automatic and some are adjustable to adjust the superheat. If the valve is inside the cabinet then don't worry about it, although some are on the outside of the cabinet or A-Coil.
Dan Hagman
ProSite Home Inspections
Casey, O'Malley & Associates Home and Commercial Education Classes and Conferences
Similar Threads
Expansion Joints Ron Gries Building Envelope: Home Inspection and Commercial Inspection 25 02-17-2009 08:34 PM
Expansion tanks mathew stouffer Plumbing System: Home Inspection and Commercial Inspection 1 04-28-2008 10:33 AM
Expansion tanks mathew stouffer Plumbing System: Home Inspection and Commercial Inspection 0 04-28-2008 10:30 AM
Valve attached to PR valve on H20 HEATER brian Beach Plumbing System: Home Inspection and Commercial Inspection 21 10-30-2007 06:47 PM
Business Expansion. David Banks Business Operations: Home Inspectors & Commercial Inspectors 8 08-10-2007 06:02 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
vB.Sponsors
Ad Management by RedTyger
