LinkBack (1) Thread Tools Search this Thread
  1 links from elsewhere to this Post. Click to view. #1 (permalink)
Old 06-03-2007, 06:47 PM
Miriam Barton Miriam Barton is offline
Suggestions for recommendations
Have a situation where in the home inspection we discovered some rust in air/heat ducts that are located in the concrete floor slab of the house. The master bedroom especially has a small hole that has rusted through in the bottom of the air duct and further down the air duct you can make out more rust and possibly rust holes. This was the major problem, as the other only occurence of rust was in another bedroom and the only rust was where there were three nails located on the ducts further down.
Thinking of suggesting either concrete be poured in and all new duct work be done from the ceiling or just busting up the concrete in that master bedroom and replacing the duct work in that particular room. Here is my concern, from the photos I was able to take of further down the duct work in the master bedroom, there appeared there was a water line mark which was past the last rust that appeared to be holes. Supposedly they had high rain water close to flooding at some point last month and water might have gotten into the air ducts.
Should we recommend a restoration company or a HVAC company to be able to make these types of repair (running new air ducts or busting up the concrete and replacing the duct work)? Or is there other alternatives that we can suggest? There is a coating and lining service in town that we have used on a house we owned that showed some light rust from moisture, but since this hole at this house is on the bottom of the duct, I'm thinking there might be a foundation problem, though nothing we could visibly see. Might even be a leak from the master bathroom shower drain?
I'm thinking probably test for possible mold too?
File Type: jpg further down duct with appearance of additional rust holes.jpg (43.1 KB, 24 views)
Home inspection
Old 06-03-2007, 07:05 PM
Re: Suggestions for recommendations
Seal off the old system and replace with new attic or drop ceiling system.
It will be cheaper and better in the long run.
Mr. Inspector.net, Inc.
Allen, Texas 75002
Old 06-03-2007, 07:14 PM
Bruce Breedlove's Avatar
Bruce Breedlove Bruce Breedlove is offline
This is one of the many drawbacks to slab homes. In my opinion the new ducts should be run in the attic. Installing new ducts in the slab is asking for trouble all over again. The ducts flooded once; why shouldn't they flood again?
Bruce Breedlove
www.avaloninspection.com
Old 06-03-2007, 07:20 PM
Joe Nernberg's Avatar
Joe Nernberg Joe Nernberg is offline
Ditto to the above post.
Not as common in southern California. Ducts were "gurgling" while I was running the heating system on a rainy day last year. I don't spend a lot of time on the possible fix - just what's wrong.
Old 06-03-2007, 09:17 PM
Thank you all for your input.
Any one know the average cost of filling in the old duct work in the floor and running new duct work through the attic? How pricey could it be?
I'm assuming any HVAC company could be contacted to have this done, correct?
So appreciate the help.
  #6 (permalink)
Old 06-03-2007, 09:36 PM
Richard Rushing's Avatar
Miriam,
Yes.... an HVAC contractor.
Price? Just not enough information to be able to guess. How many levels, How many units, is the attic easily accessible, are your units already appropriately sized or are they under or over-sized (tonned), what about return air??
There are just too many varriables to even put a W.A.G. (wild arse guess)to the cost.
Rich
Richard Rushing, HCRI
Duncanville, Tx.
  #7 (permalink)
Old 06-03-2007, 10:00 PM
Hi Rich:
I'm talking about a 2400 square foot one level home, The attic is easliy accessible, using the same heat/air unit as they are the correct size and the return air registers are both in the attic already and no problem with them.
Just a matter of filling in the old duct work that is originally in the concrete floor of the house (that has rust and water damage) and usining the existing air/heat unit but run new duct work and vents through the attic instead.
Does that help a little?
Thanks!
  #8 (permalink)
Old 06-04-2007, 05:42 AM
Scott Patterson's Avatar
I would hesitate to get pricing from a group of home inspectors. I think you will find a vast difference in pricing around the country. If I recall a ballpark insurance figure is around $7 to $9 per lineal foot of duct.
Call up a local HVAC contractor and they should be able to give you a range in price for your area.
Scott Patterson
  #9 (permalink)
Old 06-04-2007, 05:58 AM
Miriam,
I just looked up the pricing for your area (Ok city-- is what I used) and you should count on between $225 and $250 per room/run (ex; 10x+250=betweem $2250-$2500+ service chg and any applicable taxes)
I use Xactimate 24 so my pricing is based on insurance standards and costing of specific areas of the country not general pricing.
Hope this helps...
Rich
Duncanville, Tx.
  #10 (permalink)
Old 06-04-2007, 07:07 AM
Thank you so much Rich. That does help a lot, I wanted to know about an average for budgeting purposes. Not even knowing off hand was kind of scary thinking it might run up to $10,000. But since it appears it might run lower than $5,000 that eases the situation.
  #11 (permalink)
Old 06-04-2007, 02:32 PM
Jim Robinson's Avatar
Jim Robinson Jim Robinson is offline
Just to put another thought into your head, check into running PEX for hot water baseboard. You're essentially installing a new system anyhow. However, I guess if you need AC, forced air is probably the way to go. Not much AC in my area, but there probably would be in OK.
  #12 (permalink)
Old 06-04-2007, 05:25 PM
Bob Harper's Avatar
If you discontinue those old ducts, they will still present a health hazard as they breed all sorts of goobers and goblins. Probably need to bust them out and backfill appropriately.
While I hate the thought of ducts outside the thermal envelope of the home, this is one case it may be better as long as they are installed properly and sealed.
Home inspection
LinkBacks (?)
LinkBack to this Thread: http://www.inspectionnews.net/home_inspection/heating-ventilation-air-conditioning-hvac-home-inspection-commercial-inspection/1434-suggestions-recommendations.html
Posted By For Type Date
SwiftPageEmail Subject: Inspection Radio Weekly Review - Issue 7 This thread Refback 06-06-2007 04:55 PM
vB.Sponsors
Ad Management by RedTyger
