Old 06-04-2007, 11:07 AM
Michael Thomas's Avatar
Identifying Stream Systems
Condo in 30 unit 1920s vintage building. Two pipe system at radiators, no access to boiler. It's June, heating system not running. How can I determine if this has been converted to a hydronic, or remains a steam system?
Old 06-04-2007, 11:28 AM
Brian E Kelly Brian E Kelly is offline
Re: Identifying Stream Systems
One way is the return condensate piping should go directly into boiler and the steam boiler the piping goes into a type of loop. Also the vents on the radiators should have a different vent and most important is the steam boiler has a sight glass to see the water level in the boiler. If you have a photo post and I can look at it better.
Well thats my 2 cents.
Brian Kelly
Kelly Home Inspections
Old 06-04-2007, 11:31 AM
"no access to boiler"
Old 06-04-2007, 11:34 AM
neal lewis neal lewis is offline
If it's a 2 pipe steam system, there is no air vent on the radiator. You will see a steam trap at the base of the radiator at the pipe. (Link to steam trap)
The hydronic system will have a air bleeder valve at the top of the radiator.
MarshSteam.com - Marsh Steam Traps
Old 06-04-2007, 11:54 AM
Thanks. I was aware of looking for the thermostatic traps, and of the fact that that on a two pipe steam system the inlet pipe is usually at the top of the radiator. But around here a lot stream systems ave be converted to hydronic, and I was just wondering if anyone could think of any other way to tell if that has happened without access to the boiler - for example, will a converted system function if the TTs remain in the system?
Similar Threads
Identifying hardcoat stucco & EIFS Scott Dana Building Envelope: Home Inspection and Commercial Inspection 50 01-28-2008 04:08 PM
Inspecting PV systems Michael Thomas Electrical Systems: Home Inspection and Commercial Inspection 0 05-09-2007 07:24 AM
Laars Heating Systems Recalls Gas Boilers and Water Heaters Brian Hannigan Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 0 03-28-2007 03:39 PM
Laars Heating Systems Recalls Gas Boilers and Water Heaters Brian Hannigan Plumbing System: Home Inspection and Commercial Inspection 0 03-28-2007 03:39 PM
4,334 Archived Exterior Systems Posts Brian Hannigan Exterior Systems: Home Inspection and Commercial Inspection 0 03-21-2007 01:19 AM
vB.Sponsors
Ad Management by RedTyger
