Re: Terminolgy help
As long as A (primary condensate line) the opening lower then B (secondary condensate line), then those are correct.
The catch pan, which is what I called it years ago too, is the auxiliary condensate pan.
I used to use the term 'secondary condensate pan', but that was confusing as the secondary condensate opening and secondary condensate drain line were not from that pan.
