Old 06-19-2007, 11:37 AM
dan orourke dan orourke is offline
Terminolgy help
Home inspection
Old 06-19-2007, 11:55 AM
Re: Terminolgy help
As long as A (primary condensate line) the opening lower then B (secondary condensate line), then those are correct.
The catch pan, which is what I called it years ago too, is the auxiliary condensate pan.
I used to use the term 'secondary condensate pan', but that was confusing as the secondary condensate opening and secondary condensate drain line were not from that pan.
Old 06-19-2007, 01:01 PM
Re: Terminolgy help
Quote:
Originally Posted by Jeff Eastman View Post
Are the secondary drain lines (as shown in dans' arrow b) required by IRC/manufactures?
Yes.
Quote:
Are the secondary drain lines required to be insulated in attic? I'd think so since the primary is required to be insulated.
Yes.
But not auxiliary pan drain lines.
Similar Threads
Proper terminolgy needed dan orourke Plumbing System: Home Inspection and Commercial Inspection 13 05-12-2007 07:04 PM
vB.Sponsors
Ad Management by RedTyger
