Share |
Welcome to InspectionNews.
Registration is FREE!
The Cost Of Business
Cost Of Business
Old 03-08-2010, 08:43 AM
Jon mackay Jon mackay is offline
Furnace / Boiler Shutoff Location
What is the standard for the location of of the service power switch on a boiler and furnace?
I am seeing them at doorways to the basement and more often, on the unit themselves.
What should be called out?
HomeGauge Reports
Old 03-10-2010, 07:06 PM
Dave Wheeler Dave Wheeler is offline
Re: Furnace / Boiler Shutoff Location
both are needed. At the top of the stairs for an emergency shutdown and by the unit for the tech
Old 03-11-2010, 05:30 AM
I see, Is there a date that this rule came into play?
Does anyone have documentation on this?
I always like to be able to back up my findings.
Thank you for the info.
Old 03-11-2010, 07:25 AM
Wayne Carlisle Wayne Carlisle is offline
I'm not aware of a disconnect required at the top of the stairs but one is required at the unit itself or within site.
TABLE E4001.5
DISCONNECTING MEANS
Air-conditioning condensing units and heat pump units.
A readily accessible disconnect within sight from unit as the only allowable
means. *a
a. The disconnecting means shall be permitted to be installed on or within the unit. It shall not be located on panels designed to allow access to the unit.
Old 03-11-2010, 08:39 AM
Jim Robinson's Avatar
Jim Robinson Jim Robinson is offline
What is this 'basement' that you guys are speaking of. Just at the unit itself around here, unless you count the breaker panel as a shut off. Generally just a plug that can be removed from the receptacle outlet.
  #6 (permalink)
Old 03-11-2010, 09:39 AM
Thank you Wayne, what is that from? NRC?
Jim, A basement is one or more floors of a building that are either completely or partially below the ground floor.
  #7 (permalink)
Old 03-11-2010, 09:41 AM
You're welcome!
It's actually from the 2006 IRC but the NEC has the same wording or real close to it!
Inspection Conference
Cost Of Business
Share |
Similar Threads
Location of A/C Evaporator Coils At Downdraft Furnace Bruce Breedlove Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 5 11-14-2009 06:19 PM
Location of furnace and hot water heater Margie DelGesso Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 4 07-19-2009 10:59 AM
Gas shutoff valve for gas range/oven Scott Hurt Built-In Appliances and Systems: Home Inspection and Commercial Inspection 17 07-14-2009 06:00 PM
Flexible Gas Line and Shutoff in Cabinet Matthew Barnicle Plumbing System: Home Inspection and Commercial Inspection 25 01-24-2009 08:04 AM
Furnace location Tom Rees Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 2 08-15-2008 10:35 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
vB.Sponsors
Ad Management by RedTyger
