Share |
Welcome to InspectionNews.
Registration is FREE!
The Cost Of Business
Cost Of Business
Old 03-15-2010, 01:13 PM
Sam Morris Sam Morris is offline
Air Handler Mounting Requirements
I inspected a new house today and noticed the air handler in the crawl space was not mounted to the floor joist, it was sitting off the ground on top of cinder blocks. Would this be acceptable.
3D Inspection System
Old 03-15-2010, 01:26 PM
A.D. Miller A.D. Miller is offline
Banned
Re: Air Handler Mounting Requirements
SM:
Installation in the under-floor space can be accomplished on a slab of concrete or by support from the floor joists. If on a slab, 3" above grade. If on supports, 6" above grade.
See: IRC 1305.1.4, et al.
Even if the cinder blocks were allowed, and they are not, they are lying in the wrong direction. The voids must always face vertically for proper support.
Old 03-15-2010, 06:57 PM
Bruce Ramsey's Avatar
Bruce Ramsey Bruce Ramsey is offline
A.D. you left out some of the code that may allow the use of cinder blocks, albeit in the correct orientation.
M1305.1.4.1. Ground Clearances. Appliances supported from the ground shall be level and firmly supported on a concrete slab or other approved material extending above the adjoining ground. Appliances suspended from the floor shall have a clearance of not less than 6 inches from the ground.
Bruce Ramsey
Advocate Inspections
www.NCAdvocate.com
Old 03-15-2010, 07:06 PM
Jerry Peck's Avatar
I doubt the concrete blocks would still be acceptable as the unit would need to be secured to them in some way, their contact point in the correct orientation would be limited to the top of the face shells and webs (which is likely why they were installed sideways), and other reasons the concrete blocks would not likely be acceptable for that use (unless topped with a large flat concrete or wood pad, say a 20" x 2" concrete pad (like a stepping stone) set on top of the concrete block. Of course, the concrete blocks in the proper orientation would sink into the ground (another reason they were likely set as they were) and would then need another large concrete pad underneath the concrete blocks ...
Old 03-16-2010, 04:18 AM
Banned
In my service area, where we have some of the most expansive clay soil on Earth, cinder blocks would not be an "approved material", as they would likely move independently of one another, i.e. differentially, and thereby move the unit. The unit might not mind, but the wiring, gas lines, ducts, etc. might. . .
Home Inspector Essentials. The BEST prices for inspection tools.
Cost Of Business
Share |
Similar Threads
Air/handler in Attic JIM MURPHY Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 7 08-29-2009 08:01 AM
Mounting Range Convenience Outlet Gary Anglin Electrical Systems: Home Inspection and Commercial Inspection 15 04-13-2009 08:27 AM
Air handler question David Cervantez General Chit Chat: Home Inspectors & Commercial Inspectors 5 01-25-2009 05:50 PM
Auto Reverse Sensors Mounting Height Nick Ostrowski Environmental, Pests, Health and Safety: Home Inspection and Commercial Inspection 6 02-11-2008 11:50 AM
Air handler plenum william siegel Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 8 04-21-2007 12:33 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
vB.Sponsors
Ad Management by RedTyger
