Originally Posted by
David Bell
Looks like the put a piece of pipe together and push method was used. Even with tight spaces like that, pipe sleeve insulation is an option.
Yes, I was able to access and it wasn't too bad for moving around. No tape used at the seems and multiple gaps. No reason not to insulate.
This was an odor complaint inspection for a small commercial building.
There was quite an odor comming from the blower compartment at the return side. I found a very large gap at one pipe and multiple small gaps at the connections.
