Old 07-17-2007, 01:57 PM
Jake Guerrero's Avatar
Jake Guerrero Jake Guerrero is offline
Return air balance
I inspected a new home the other day where the master bedroom seemed like it was pressurized (I would close the door, and the door would be 'sucked' into the frame).
I had 2 supply vents in the master bedroom, and at least one in the adjoining master bath (maybe two, I can't recall..the master bath was large).
There was a return air vent about 7 feet on the ouside of the master bedroom in a hall area. The unit served master bed and bath, an office, and part of another living area.
To cicumvent this problem (besides more space between the door and floor) I have seen return air sized ductwork run in the attic between living areas, with return air grilles and no filters (looks like a big Slinky when u see it in the attic).
My question is...is there an industry term for the extra ductwork supplying more return air from a living area? I suppose a small return vent could be installed in the master bedroom and vented with the main hallway since they are so close.
Jake
Old 07-17-2007, 02:24 PM
Jim Luttrall Jim Luttrall is online now
Re: Return air balance
Jumper duct is the term that comes to mind.
Jim
Mr. Inspector.net, Inc.
Allen, Texas 75002
Old 07-17-2007, 05:19 PM
Or 'bridge duct'.
Or 'balance duct'.
Or ... Phillip, Kevin and the other HVAC guys will likely add more terms.
Old 07-17-2007, 05:31 PM
Thanks. I'll use whichever of these I think of first
Old 07-17-2007, 10:51 PM
Phillip Stojanik's Avatar
Phillip Stojanik Phillip Stojanik is offline
"Jumper ducts" or just "jump duct" is what we call them here.
If it were me though I would just add a 12" by 24" return-air-filter-grill in the ceiling and duct it to the return plenum of the system rather than using a passive jumper duct system.
Similar Threads
Return for repairs, Stinger Strion? Tim Moreira Tools and Equipment 5 08-29-2008 03:46 PM
Fresh Air Return K Robertson Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 5 05-17-2007 09:12 PM
Return Air David Banks Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 24 05-12-2007 05:27 AM
Exposed wood joist in return air John Tullous Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 15 05-08-2007 07:27 PM
return over range in kitchen wes owens Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 14 04-27-2007 10:56 AM
vB.Sponsors
Ad Management by RedTyger
