Old 07-26-2007, 04:41 PM
Rust inside 2004 furnace
Old 07-26-2007, 04:50 PM
Phillip Stojanik's Avatar
Phillip Stojanik Phillip Stojanik is offline
Re: Rust inside 2004 furnace
Quote:
Originally Posted by Jeff Eastman View Post
Ideas on what is causing the rust inside of this furnace?
Moisture?
Old 07-26-2007, 04:51 PM
Scott Patterson's Avatar
Moisture!
Scott Patterson
Old 07-26-2007, 04:52 PM
Well it looks like Phillip and I are on the same page!
Scott Patterson
Quote:
Originally Posted by Scott Patterson View Post
Moisture!
Great minds think alike eh Scott?
  #6 (permalink)
Old 07-26-2007, 05:06 PM
DavidR's Avatar
DavidR DavidR is offline
Was that the only spot in the furnace showing any signs of rust?
  #7 (permalink)
Old 07-26-2007, 05:14 PM
Richard Rushing's Avatar
My first thoughts are, two:
1) There obviously could be moisture running down the flue.
2) The moisture could be created by a short purge-cycle that doesen't allow for the hot combustion fumes to exit out thru the roof. The result would be the cold air in the attic would cause condensation to form on the outside and drip back down.
Or, there could have been a circus in town that had a monkey escape. The monkey climbed the roof and urinated down the chimney...
Richard Rushing, HCRI
Duncanville, Tx.
  #8 (permalink)
Old 07-26-2007, 05:21 PM
I would vote on condensation down the flue pipe. But this is only a guess. This is one of the camels that folks strain on but watch out for the gnats they will choke you!
This would not even make my report.
Scott Patterson
  #9 (permalink)
Old 07-26-2007, 05:57 PM
wayne soper's Avatar
I agree, condensation between cycles.
  #10 (permalink)
Old 07-27-2007, 03:06 PM
DavidR's Avatar
Scott if you run up on this it needs to make a report if it's from the flue gases as it is a defect, flues are not meant to condense on the inside unless it's a condensing furnace.
There are ways to fix these condensation issues that require the addition of a post purge circuit.
  #11 (permalink)
Old 07-27-2007, 04:31 PM
Could be, but this IMO is way outside the scope of a home inspectors job. Now, if you have an HVAC background and you see this as a problem you will not agree with my philosophy. Chances are that the small amount of rust stains were just one of several other signs that one could see if we had an entire picture of the flue pipe, etc.
Based on that picture, I do not see it as a problem and truth be known I don't know if I would have even seen it unless there were some other signs.
Scott Patterson
Similar Threads
Wiring inside the chimney area Mike Pearson Fireplaces, Chimneys and Solid Fuel Burning Appliances: Home Inspection and Commercial Inspection 2 07-23-2007 09:11 AM
Electrical cable inside of chimney chase dan orourke Electrical Systems: Home Inspection and Commercial Inspection 3 07-18-2007 08:29 PM
Rust on bus bar, breaker screws RobertSmith Electrical Systems: Home Inspection and Commercial Inspection 1 07-06-2007 08:59 AM
Low voltage/rust Roni Litmanovic Electrical Systems: Home Inspection and Commercial Inspection 1 04-30-2007 11:40 AM
rust on gas meter Jeff Eastman Plumbing System: Home Inspection and Commercial Inspection 4 04-16-2007 11:46 AM
vB.Sponsors
Ad Management by RedTyger
