Old 08-04-2007, 10:47 AM
Nick Ostrowski Nick Ostrowski is online now
Galvanized Pipes on Hot Water Heating Systems
I've been noting in my reports the presence of galvanized pipes on runs of hot water heating pipes for hydronic heating systems. I started wondering if galvanized pipes will have an affect on the performance of a hot water heating system in the same way they can affect water pressure over time in the potable water pipes. I know that the water contained in the hot water heating pipes becomes essentially chemically inert over time and may or may not cause the pipes to corrode from the inside out.
Any thoughts?
Old 08-14-2007, 06:37 AM
Re: Galvanized Pipes on Hot Water Heating Systems
Anyone? Bueller? Bueller?
Old 08-14-2007, 07:53 AM
neal lewis neal lewis is offline
Nick,
The oxygen in the water causes the rust buildup and reduces the water flow in water supply piping.
I have not heard of the same problems with hydronic heat. But, generally I see black iron for heating. I don't know about the inert quality of the water.
Old 08-14-2007, 05:54 PM
imported_John Smith imported_John Smith is offline
Typically, you see calcium deposits choking off the pipes, and rust and pinholes developing under the calcium deposits. Anode+Cathode+Electrolyte = corrosion.
Corrosion is most aggressive on hot water piping as the temperature has a significant influence on corrosion rates. In a hot attic, with hot water - you are in the real sweet spot of corrosion development.
But - consider that the pipes are usually not the same temperature as the water in the heater because they lose heat when no hot water is flowing through them. In hot climates like Houston, most transplants from the North think they have a problem with their hot/cold water service as the cold typically puts out very hot water during our brutal summers.
Similar Threads
where all the vent pipes are above average John Arnold Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 0 07-27-2007 03:00 PM
galvanized piping Scott Lynch Plumbing System: Home Inspection and Commercial Inspection 5 07-22-2007 07:36 PM
Galvanized gas supply line and fittings. Trent Tarter Plumbing System: Home Inspection and Commercial Inspection 2 07-19-2007 06:55 PM
Laars Heating Systems Recalls Gas Boilers and Water Heaters Brian Hannigan Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 0 03-28-2007 03:39 PM
Laars Heating Systems Recalls Gas Boilers and Water Heaters Brian Hannigan Plumbing System: Home Inspection and Commercial Inspection 0 03-28-2007 03:39 PM
vB.Sponsors
Ad Management by RedTyger
