Old 04-03-2007, 08:37 PM
Martin lehman's Avatar
Martin lehman Martin lehman is offline
a/c disconnect
Inspected a unit today and the disconnect was an actual switch - like a light switch.
I really don't see how this could be OK. It's too easy for the switch to restore power to the unit. If the tech were to accidentally hit the switch it would restore power in an instant.
Old 04-03-2007, 08:46 PM
Rick Hurst's Avatar
Rick Hurst Rick Hurst is online now
Re: a/c disconnect
Martin,
Was this "switch" located on the outside condensing unit or at the inside HVAC equipment?
Old 04-03-2007, 09:31 PM
Tim Moreira's Avatar
Tim Moreira Tim Moreira is offline
Re: a/c disconnect
I have seen where a "light switch" type was used as a disconnect, but it would have to be rated for the correct amps.
Also, if it was on the exterior, then it should have a spring loaded cover plate that you have to open to access and it would close automatically. This would ensure that it could not be bumped accidentally.
Old 04-03-2007, 09:52 PM
Re: a/c disconnect
The switch was located at the condensor outside. It did have a spring loaded cover and was rated for exterior use.
I'm still gonna call it out. It just does not seem safe to me, even if it has a spring loaded cover .
BTW, Tim how did you get the text on your signature to link to your website? As you can see I obviously cannot do it.
Old 04-03-2007, 10:22 PM
Re: a/c disconnect
Martin,
When the new board came on line and I wanted to re-create my signature like it was on the old board I found out that I hadn't had a clue to how I did it before.
So with that being said, I did the next best thing and went to one of Brian's archived posts that brings you back to the old board.
Go to the InspectionNews at the top left of the page and click on it. Then scroll down till you find one of Brian's threads on the right hand side that says ******archived posts. (******are the number of previous posts on that site) click on it and then click on the archived posts under Brian's picture. It will take you back to the old board.
Once there, I found an old post of mine and clicked on the edit button next to the profile, email, and edit button next to my name on that post.
This shows you all of the computer geek code programming. I then scrolled down and did a copy/paste to my signature on the new board under the "User CP" tab and walla....the link to my web page is back just like it was on the old board.
Here is my link with an additional space at the very end so the board doesn't recognize it and make it another link:
[url=http://www.Suncoasthomeinspector. com]
I added the space after the "dot" and before the "com". Retype yours exactly like this without the space between the dot and com and you should be able to create a link to your homepage.
HTH
  #6 (permalink)
Old 04-03-2007, 11:25 PM
Re: a/c disconnect
Try that, if not ask Brian to help. I just tried entering you info but it may have been incorrect as to your web page.
  #7 (permalink)
Old 04-03-2007, 11:48 PM
Brian Hannigan's Avatar
Brian Hannigan Brian Hannigan is offline
Administrator
Re: a/c disconnect
Quote:
Hi Martin,
Go here:
http://www.inspectionnews.net/home_i...?do=bbcode#url
and look at the line that says "URL Hyperlinking". It should be at the top of your screen. Please let me know if you have any trouble.
BTW, are referrals from past clients important to you? If so, watch this Video
Sincerely,
Brian Hannigan
Hann Tech Marketing Links
http://www.HannTech.com
http://www.InspectionNews.net
http://www.InspectionRadio.com
http://www.CostOfBusiness.com
http://www.AccessMyReport.com
aaa-CaliforniaHomeInspection.com
http://www.HomeInspectorLocator.com
Home inspection
vB.Sponsors
Ad Management by RedTyger
