Old 08-18-2007, 09:46 PM
Kevin Luce's Avatar
Kevin Luce Kevin Luce is offline
Clearance for an air conditioner
I'm wondering if there have been any carrier unit that allow under 24 inch clearance from top of unit. My thinking is no. I did a search but no luck on Carrier units.
I say lets merge all the home inspection organizations into one.
Seepaluce
Old 08-20-2007, 07:56 AM
Eric Barker's Avatar
Eric Barker Eric Barker is online now
Re: Clearance for an air conditioner
My rule of thumb is 4 feet min., unless otherwise specified by manuf.
Eric Barker
Barrington, IL
Old 08-20-2007, 09:52 AM
Brian E Kelly Brian E Kelly is offline
Depending on the model the clearances are different. The York units have 2 clearances depending on the model. The min. height clearance is 48" and the other units have a 60" clearance. I imagine that Carrier might have the same situation.
Well thats my 2 cents.
Brian Kelly
Kelly Home Inspections
Old 08-20-2007, 09:53 AM
Jeff Euriech Jeff Euriech is offline
This Carrier unit calls for 48".
http://www.docs.hvacpartners.com/idc/groups/public/documents/techlit/24aba-1si.pdf?SMSESSION=$SM$%2f0I2fGDwN1Zlj7kbsZLBulJkU7 rgN4715MJJQ%2f5bOUZaib5ISfLLSZud97Ep2%2flDLafmO0rd itJMoSG5wVnR23tedmJ3nGkE%2f9htGsLWvLTURlvnexNFXRu1 %2f1RUZtptHMBVshWYCTwLayREgs1nw9t0SvfxLRcX54%2bGgv nrJKTVnJburqdOB0iYBSK9%2b%2bwD26y5aBBLTs4%2feI09ib 5kI%2f1BA52h399g8QBrePd%2fMIyVXUn25vMcZx97PbJ0Ro9i UVqn452XBvzxJsn9p85uHcmRQyoANtqMb8AXkaD4Ipv2M4%2f9 1OocsH5Lb8zYOIT9307FpSU9HEw%3d
Jeff Euriech
Peoria Arizona
Old 08-20-2007, 10:14 AM
Jeff what are the letters and numbers after the .com???
Brian Kelly
  #6 (permalink)
Old 08-20-2007, 10:19 AM
Jim Luttrall Jim Luttrall is online now
Brian, that is the full web address.
Copy and paste the entire string into you address bar and it takes you to the pertinent information. I just tried it and it works for me.
Jim
Mr. Inspector.net, Inc.
Allen, Texas 75002
  #7 (permalink)
Old 08-20-2007, 10:21 AM
STEP 3.—
Clearance Requirements
When installing, allow sufficient space for airflow clearance,
wiring, refrigerant piping, and service. Allow 30--in. clearance to
service end of unit and 48 in. above unit. For proper airflow, a
6--in. clearance on 1 side of unit and 12 in. on all remaining sides
must be maintained. Maintain a distance of 24 in. between units.
Position so water, snow, or ice from roof or eaves cannot fall
directly on unit.
Jim
Allen, Texas 75002
  #8 (permalink)
Old 08-20-2007, 11:41 AM
Bruce Breedlove's Avatar
Bruce Breedlove Bruce Breedlove is offline
You can make it easier for everyone by creating a link to the site like this:
Carrier Installation Instructions
To create a link simply type the following:
{url= WEB SITE ADDRESS (e.g., www.inspectionnews.net) } WEB SITE NAME {/url}
NOTE: Replace the { } brackets with [ ] brackets.
Bruce Breedlove
www.avaloninspection.com
Similar Threads
B Vent Window Clearance Jim Robinson Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 9 06-16-2007 09:11 AM
Gas Fireplace Chimney Clearance Jon mackay Fireplaces, Chimneys and Solid Fuel Burning Appliances: Home Inspection and Commercial Inspection 15 05-16-2007 04:18 PM
insualation clearance from draft hood dan orourke Plumbing System: Home Inspection and Commercial Inspection 9 05-03-2007 07:24 PM
Who needs 6" of clearance for single wall Paul Kondzich Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 5 04-28-2007 07:17 PM
Propane regulator clearance Jim Luttrall Plumbing System: Home Inspection and Commercial Inspection 13 04-16-2007 08:30 AM
vB.Sponsors
Ad Management by RedTyger
