Old 08-27-2007, 07:46 PM
Jim Luttrall Jim Luttrall is online now
Condensate drain diagram
Does anyone have a correct diagram or picture of a horizontal (attic) mounted A/C unit with both primary and secondary traps with the vent in the proper location? I would love to have a diagram I could put in my reports to show how it is supposed to be done.
I keep looking for a correct example on my inspections, but NOBODY does it right! I have gotten close a couple of times, but there is always some kind of defect that I do not want to use as an example.
Thanks, Jim
Mr. Inspector.net, Inc.
Allen, Texas 75002
Home inspection
Old 08-27-2007, 08:02 PM
Rick Hurst's Avatar
Rick Hurst Rick Hurst is online now
Re: Condensate drain diagram
Jim,
I think Jerry Mc. posted one on here before but I can't locate it at this moment. Maybe he can find it if he did.
Your right, I've never seen the condensate drain lines done correctly either. Seems something is wrong with all of them.
Found one close the other day but it had condensation pouring out of the secondary to the exterior. So no go.
It looked correct looking down at it from the front of the unit, but looking at it from the side it was obvious the primary drain line was running uphill causing the condensate to back up into the coil and drain to the secondary.
Rick
Old 08-27-2007, 08:07 PM
BARRY ADAIR's Avatar
BARRY ADAIR BARRY ADAIR is offline
As I recall a great deal of discussion took place over this
This is what both of today's looked like
Yep, that's over an inch of rusty water in that pan. No float or moisture sensor.
Residential-Commercial-Construction-EIFS-Infrared Thermography
Old 08-27-2007, 08:39 PM
Your right Barry, that is part of the reason I was so specific in my request. I wanted to avoid beating that horse to death again
Allen, Texas 75002
Old 08-28-2007, 07:23 AM
fritzkelly fritzkelly is offline
I have never seen a trap on the secondary from a pan and can't think of any reason for one. Is that required where you are?
  #6 (permalink)
Old 08-28-2007, 07:38 AM
Scott Patterson's Avatar
Thanks, Jim
I took this picture of an installation manual last week at an inspection. Sorry it only talks about the secondary drain. In my area the AHJ's do not require a secondary if a pan is installed with an automatic cutoff attached in the pan.
Scott Patterson
  #7 (permalink)
Old 08-28-2007, 09:16 AM
Jerry McCarthy's Avatar
Jim
This is all I could find in my files at the moment - hope it helps?
Construction Consultant
  #8 (permalink)
Old 08-28-2007, 10:13 AM
Fritz, we are tripping over terminology I think. I don't want to tread on Jerry P's turf here by correcting anyones terminology, but for the sake of clarity, there are three distinct drain systems in most attic mounted a/c units here. The primary drain, the secondary drain, and the emergency or overflow pan and drain.
Both the primary and secondary drain ports connect to the evaporator drain pan inside the cabinet and will leak conditioned air out the pipe if there is no trap or if the vent is installed on the wrong side of the trap on the primary.
The emergency overflow pan does not need a trap since it is just an external pan and drain to a conspicuous location.
Scott the verbiage above the diagram that says in black and white that both the primary and secondary need to be trapped is very helpful. Any idea what brand of unit or model that was?
Thanks Jerry M. I think I have already stolen most of those from your previous posts, but I will check my files, you never know when you are going to need a good diagram.
I am still looking for that holy grail photo or diagram that shows everything correct though.
Thanks everyone!
Jim
Allen, Texas 75002
  #9 (permalink)
Old 08-28-2007, 11:20 AM
Michael Thomas's Avatar
Jim,
That diagram is in all the Lennox installation manuals, for example:
http://www.hvac-direct.com/pdf_files...on/505059c.pdf
  #10 (permalink)
Old 08-28-2007, 11:28 AM
Screen captures for anyone who needs them:
  #11 (permalink)
Old 08-28-2007, 11:46 AM
Thanks Michael, I have looked at several Lennox and other instruction sheets and never found the clear cut verbiage until today from you and Scott.
BTW, what program do you use for the screen capture?
Jim
Allen, Texas 75002
  #12 (permalink)
Old 08-28-2007, 12:00 PM
Jim, most installs I see have the secondary draining to the pan which drains to the exterior. Secondary is just elbowed down to drip into the pan, no trap. Sounds like the consensus is that there should be a trap on the secondary whether it drains directly to the exterior or to the pan. I don't believe I've ever seen this done.
  #13 (permalink)
Old 08-28-2007, 12:15 PM
Fritz, I will agree with you on that, almost every one I see is wrong even in new builds.
I see bunches of pans that have big rust spots under the secondary pipe due to condensation forming in the pan from the cold air blowing on it.
As I tell my customers, go up in the attic and pass your hand near the a/c unit and connections when it is running. If you feel cold air; it is wrong.
Simple explanation that is easily understood by everyone except the guy running the condensate drains!
I also add to use mineral oil to prime the secondary trap to provide for and prevent evaporation of the trap seal.
For those math whizzes out there, I would like to see an annual dollar cost of energy for those 3/4 inch holes. I also wonder if the duct blaster testing guys seal those holes during the test. It seems an open 3/4 inch hole or two would eat up most of the leakage tolerance for the duct system. I have read some less than flattering practices for the energy rater techs that work for the builder though.
Jim
Allen, Texas 75002
  #14 (permalink)
Old 08-28-2007, 12:22 PM
MW Snap here on the laptop. It's pretty good, but I have a better one on the office computer, can't remember its name offhand, I'll have to look it up.
Meanwhile, can someone point me to the code section which requires that condensate indirect waste drain connections be air gaps rather than air breaks?
File Type: gif DWV - Air Gap vs Air Break - Diagram.gif (3.4 KB, 73 views)
  #15 (permalink)
Old 08-28-2007, 12:27 PM
Close.
- The primary drain,
- the secondary drain,
- the auxiliary pan and drain
- a cutoff switch which will shut the unit off and allow overflowing condensate to run all over, damaging whatever it can
  #16 (permalink)
Old 08-28-2007, 12:49 PM
Quote:
INDIRECTWASTE PIPE. A waste pipe that discharges into
the drainage system through an air gap into a trap, fixture or
receptor.
While nothing "allows" for the condensate to be connected to a sanitary drain, that would be an "indirect waste" and would fall under the requirements for, and definition of, "indirect wastes", see above.
However, the above said, I will repost the code section which does not allow for condensate to be connected to the sanitary waste system through the trap as shown in that drawing:
- P2706.3 Prohibited waste receptors.
Plumbing fixtures that are used for domestic or culinary purposes shall not be used to receive the discharge of indirect waste piping.
- - Exceptions:
- - - 1. A kitchen sink trap is acceptable for use as a receptor
for a dishwasher.
- - - 2. A laundry tray is acceptable for use as a receptor for a
clothes washing machine.
I.e., the only traps/fixtures used for domestic OR culinary purposes which are allowed to receive indirect wastes, and the only wastes those are allowed to receive are: 1) kitchen sink trap may receive waste from a dishwasher; 2) laundry tray/sink may receive waste from the clothes washing machine.
  #17 (permalink)
Old 08-28-2007, 01:26 PM
Thanks.
So, in theory at least, most every drain pan on a utility room floor is incorrectly plumbed...?
Oh man... no way I'm gonna' win *that* battle...
  #18 (permalink)
Old 08-28-2007, 01:57 PM
So, in theory at least, most very drain pan on a utility room floor is incorrectly plumbed...?
Yep.
You can, it just takes patience and stick-to-it-tiveness.
Here is the reference for the water heater pan drain:
P2801.5.2 Pan drain termination.
The pan drain shall extend full-size and terminate over a suitably located indirect waste receptor or shall extend to the exterior of the building and terminate not less than 6 inches (152 mm) and not more than 24 inches (610 mm) above the adjacent ground surface.
Correct, "over", not "into" or "in". And that "over" height must meet the air gap space requirements shown in the code, basically twice as high above the drain as the pipe is large, 2" minimum (basically - it's more complicated, as I showed in the other rece
