Old 04-04-2007, 08:49 PM
Kevin VanderWarf's Avatar
Kevin VanderWarf Kevin VanderWarf is offline
No replies in the roofing section, maybe here
Flu pipe between a turbine vent and side wall. Also a ridge vent above.
I don't see those turbine vents around here so I'm not sure about it.
I need some ideas on this so I finish the report.
Consistency is a direct path to perfection.
Home inspection
Old 04-05-2007, 12:37 AM
Phillip Stojanik's Avatar
Phillip Stojanik Phillip Stojanik is offline
Re: No replies in the roofing section, maybe here
Kevin,
Forget the wind driven turbin, the problem is the adjacent vertical wall!
Old 04-05-2007, 10:03 AM
Well Phillip,
That's what I thought, but just for curiosity, if not for the vertical wall what would be the rule for the turbine and flu.
Old 04-06-2007, 09:17 AM
Richard Rushing's Avatar
IRC. G2427.6.5 (503.6.6) Gas vent termination. A gas vent shall terminate in accordance with one of the following:- 1. Above the roof surface with a listed cap or listed roof assembly. Gas vents 12 inches (305 mm) in size or smaller with listed caps shall be permitted to be terminated in accordance with Figure G2427.6.5, provided that such vents are at least 8 feet (2438 mm) from a vertical wall or similar obstruction. All other gas vents shall terminate not less than 2 feet (610 mm) above the highest point where they pass through the roof and at least 2 feet (610 mm) higher than any portion of a building within 10 feet (3048 mm).
Old 04-06-2007, 11:12 AM
IRC says:
- G2427.6.7 (503.6.7) Forced air inlets. Gas vents shall terminate not less than 3 feet (914 mm) above any forced air inlet located within 10 feet (3048 mm).
But, that is not a " forced air *inlet* ". Just something to keep in mind, though.
I did not find reference to 'building openings', which is what I was looking for. Bob H., is there a requirement for separation from 'building openings'?
Similar Threads
Separate Section For Each State? Brian Hannigan Associations, Ethics, Standards, Licensing, Legislation:Home Inspectors & Commercial Inspectors 27 07-09-2007 12:24 PM
7,945 Archived Roofing System Posts Brian Hannigan Roofing System: Home Inspection and Commercial Inspection 0 03-21-2007 01:32 AM
vB.Sponsors
Ad Management by RedTyger
