Old 04-05-2007, 01:29 PM
Kevin VanderWarf's Avatar
Kevin VanderWarf Kevin VanderWarf is offline
Commercial zone system,
In all my years in HVAC, I never dealt with these pneumatic(?) damper controls. Either way, what ever you call it, there is this hose that's just stuck into the duct very loose.
Should there be some sort of fitting inserted into the duct to attach these to.
Consistency is a direct path to perfection.
Old 04-06-2007, 10:56 AM
Re: Commercial zone system,
Are you sure that is not an electrical wire to an electrically controlled damper?
Old 04-06-2007, 11:39 AM
Tim Moreira's Avatar
Tim Moreira Tim Moreira is offline
Kevin,
I don't know what that is, but in all my years in hospitals with pneumatically controlled dampers, I have only seen where the damper inside the duct is connected to an arm that extends to the outside of the duct and is connected to a pneumatic actuator. The pneumatic line (which is only about 20 psi or so) is connected to the actuator.
The damper is controlled most likely through a computer operated system that connects to an E/P control box. The E/P box is an 'electrical/pneumatic' control box that regulates the damper. It is also interlocked into the fire alarm via a relay. If the alarm goes off, the interlock kills the pneumatics and the damper closes automatically. All of the dampers I have seen are normally closed for this reason.
My only other thought on that line stuck in there is if it is part of a magnahealic (sp) that reads the differential pressure across the filters at the AHU. This way they know when to change the filter based on the difference in pressure on the magnahealic (sp) gages.
Last edited by Tim Moreira : 04-06-2007 at 11:32 PM. Reason: speeling and xtra info
Old 04-06-2007, 11:26 PM
Kevin,
Yes, normally a pneumatic line is not just drilled and stuffed like that. There should be a correct fitting (double sided barb) that is attached to the duct work. The line should attach to a "barb" on the outside and then another line should attach to the "barb" on the in side before terminating at the actuator.
I have never seen an actuator inside the duct. But then again...
Old 04-07-2007, 03:05 AM
Magnahealic, pneumatical, interlockin thing-a-ma-gigger.
Yep, thats what I thought it was.LOL (over my head).
I did go ahead and write up that the loose hoses need proper fittings at the duct penatrations.
Thanks for your help Tim.
Home inspection
Similar Threads
Time Zone Jim Robinson H E L P ! 2 04-02-2007 01:59 PM
7,945 Archived Roofing System Posts Brian Hannigan Roofing System: Home Inspection and Commercial Inspection 0 03-21-2007 01:32 AM
10,219 Archived Plumbing System Posts Brian Hannigan Plumbing System: Home Inspection and Commercial Inspection 0 03-21-2007 01:27 AM
vB.Sponsors
Ad Management by RedTyger
