Old 04-06-2007, 05:12 PM
Staining on exterior wall near A/C
Home inspection
Old 04-07-2007, 07:02 AM
Richard Rushing's Avatar
Re: Staining on exterior wall near A/C
Well... if there is not a condensate drain drop above it (from soffit) then it is discharge from the fan.
Is this a heat pump?
RR
Old 04-08-2007, 03:30 PM
Kevin VanderWarf's Avatar
Kevin VanderWarf Kevin VanderWarf is offline
Looks like the fan to me.
I've never liked that design.
I'm sure the folks at Trane know there stuff, but if you put 4 bricks on each corner of any other unit then placed a piece of plywood on top, it would give you about the same air distribution as the unit in the pic.
But then any other would require an 24" to 48" top clearance.
Consistency is a direct path to perfection.
Home inspection
Similar Threads
Brick Veneer Exterior Wall 90 deg inside joint imported_John Smith Exterior Systems: Home Inspection and Commercial Inspection 2 04-05-2007 06:52 PM
vB.Sponsors
Ad Management by RedTyger
