Old 10-17-2007, 04:39 PM
Clay White Clay White is offline
Flex Air Duct allowed?
Home inspection
Old 10-17-2007, 06:04 PM
Billy Stephens's Avatar
Billy Stephens Billy Stephens is offline
Re: Flex Air Duct allowed?
Clay
It's UGLY but I can't find anything that would prohibit it .
Billy J. Stephens HI Service
Old 10-17-2007, 06:08 PM
If the separation wall between the house and garage puts the duct in the garage, then the duct is wrong. If the heater is "in the house" on the house side of the separation wall between the house and garage, then it would be OK.
From what I see around here, it would be wrong since the W/H closet door would not be an approved door between the house and garage, thus the separation wall would be the back wall of the W/H closet. That would also mean the OSB would violate the separation requirement of 1/2" gypsum, assuming you are on the IRC.
Mr. Inspector.net, Inc.
Allen, Texas 75002
Old 10-17-2007, 06:20 PM
Jerry McCarthy's Avatar
Clay
Just how do you know that's a flex air duct?
Construction Consultant
Old 10-17-2007, 06:22 PM
Jim L,
IF the Left wall(duct) back wall both house walls.
Right Wall Garage.
Bring me up to speed on the door please
  #6 (permalink)
Old 10-17-2007, 07:26 PM
Quote:
Originally Posted by Clay White View Post
Rear of the closet is the master bathroom.
Right of the closet is garage space.
Left of the closet is exterior.
Clay,
So The DUCT goes outside.
  #7 (permalink)
Old 10-17-2007, 07:32 PM
Clay,
First this needs to be answered: What kind of door is it? All the door needs to be is solid core 1-3/8", i.e., just a regular old cheap 1-3/8" solid core door.
R309.1 Opening protection.
Openings from a private garage directly into a room used for sleeping purposes shall not be permitted. Other openings between the garage and residence shall be equipped with solid wood doors not less than 13/8 inches (35 mm) in thickness, solid or honeycomb core steel doors not less than 13/8 inches (35 mm) thick, or 20-minute fire-rated doors.
  #8 (permalink)
Old 10-17-2007, 09:34 PM
What Jerry said.
The entire section of R309 deals with garages and carports.
The main theory here is "309.2 Separation required. The garage shall be separated from the residence and its attic area..." and then goes on into specifics.
In general, the common walls and ceiling have to have gypsum board on the garage side and proper doors on any openings through the separation wall.
Allen, Texas 75002
  #9 (permalink)
Old 10-18-2007, 05:42 AM
To continue what Jim said ...
*IF* the door is one of the correct type doors, then the OSB ceiling is not a problem and neither is the duct.
*IF NOT* (if the door is not a correct type door), then *both* are problems.
  #10 (permalink)
Old 10-18-2007, 06:19 AM
From what I see around here, it would be wrong since the W/H closet door would not be an approved door between the house and garage, assuming you are on the IRC.
Quote:
Must be a lot of Hollow core doors in Texas . I pictured some (magical) special door based on combination of what wall is who? Appendix # ****
  #11 (permalink)
Old 10-18-2007, 08:48 AM
buddy brault buddy brault is offline
Clay the door is the key as everbody says but if it is a solid door, looks like there may be some combustion air issues.
Home Inspection Protection,LLC
Buddy Brault
  #12 (permalink)
Old 10-18-2007, 12:25 PM
Quote:
To expand on Buddy's "solid door" (not "solid core" door) statement above ...
*Even if* it is a "louvered door" (versus a "solid door") there are likely combustion issues.
In thinking about "the door" I 'thought right over' the combustion air issue (meaning I forgot about it ).
Similar Threads
# of layers allowed Clay E White Roofing System: Home Inspection and Commercial Inspection 21 10-30-2007 08:29 AM
Tight seal on Flex Duct ... Not !! Nolan Kienitz Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 0 10-08-2007 05:21 AM
Plumbers & Electricians Should Not Be Allowed Power Tools Bruce Breedlove Structural Components: Home Inspection and Commercial Inspection 10 09-25-2007 11:06 AM
A+ for effort, but is it allowed? John Stephenson Building Envelope: Home Inspection and Commercial Inspection 5 08-17-2007 05:03 PM
Is this allowed? John Stephenson Building Interior: Home Inspection and Commercial Inspection 1 06-06-2007 03:22 PM
vB.Sponsors
Ad Management by RedTyger
