Old 11-19-2007, 06:23 PM
Clay White Clay White is offline
Air duct interface with slab
Home inspection
Old 11-19-2007, 06:27 PM
Rick Hurst's Avatar
Rick Hurst Rick Hurst is online now
Re: Air duct interface with slab
If they have ducts in the slab, that bit of missing sealant around that duct is the least of their worry.
Old 11-19-2007, 07:23 PM
Quote:
Originally Posted by Clay White View Post
I fairly sure there are metal ducts in the slab.
Then this is worth repeating:
Quote:
Old 11-19-2007, 09:00 PM
Jim Luttrall Jim Luttrall is online now
Rust, water infiltration, mold, musty, nasty, rodents, etc.
Other than that, they are just fine and are still allowed with certain restrictions if you are not in a flood prone area.
Mr. Inspector.net, Inc.
Allen, Texas 75002
Old 11-19-2007, 09:02 PM
Gunnar Alquist's Avatar
Gunnar Alquist Gunnar Alquist is online now
Ducting in the slab is required to be completely encased. I cannot recall for sure, but I think it is a minimum of 2". However, they are often not encased and the bottom of the duct, in contact with soil, will rust out. In addition, as the duct is below grade, and concrete will often crack, the ducting could very well ship water into it.
Since this is a visual inspection, defer to an HVAC contractor.
The apostrophe troll.
  #6 (permalink)
Old 11-19-2007, 09:35 PM
Rick Hurst's Avatar
Ducts in the slab is just one of the contributors to the downfall use of Chlordane. Many termite control persons have actually drilled into the slab and accidentally pumped chemical into these ducts. Cleanup costs were outrageous and led to lawsuits.
I personally know of (1) case here in the DFW area.
If you like the musty smell, thats a reason to consider them I guess.
Similar Threads
Deck house flashing interface Clay White Building Envelope: Home Inspection and Commercial Inspection 2 11-06-2007 06:43 PM
Rafter interface with doubled-up 2xs Jeff Eastman Attic Areas: Home Inspection and Commercial Inspection 0 09-07-2007 01:13 PM
beam interface with shingles John Stephenson Roofing System: Home Inspection and Commercial Inspection 13 06-22-2007 02:38 AM
Siding Interface with Chimney Jeff Eastman Building Envelope: Home Inspection and Commercial Inspection 3 05-03-2007 06:42 PM
Heating duct rusted out in slab Mike Huppi Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 5 04-28-2007 02:58 PM
vB.Sponsors
Ad Management by RedTyger
