You are currently viewing InspectionNews as a guest which gives you limited access to view most discussions but not pictures. There are over 4,500 inspectors who have already joined. By joining InspectionNews you will be able to see the pictures, have access to post topics, communicate privately with other members, respond to polls, upload content and access many other special features. Registration is fast and simple so please, join InspectionNews today!
Old 11-19-2007, 08:47 PM
Carl Eisen Carl Eisen is offline
Sidewall Vent Termination
Is there any specification on the seperation needed between the intake and exhaust vents for a Rheem condensing gas furnace? I have the pictured termination that I thought should have more seperation and I have been unable to find information on this.
Carl Eisen
West Bend, WI
Old 11-20-2007, 03:01 AM
John Arnold John Arnold is online now
Re: Sidewall Vent Termination
That's probably ok. After all, there are intake/exhaust devices where the two are integrated into one.
Google Image Result for http://www.myhvacparts.com/Catalogue/Accessories/Bayvent200B.jpg
Old 12-12-2007, 06:27 AM
Michael Greenwalt's Avatar
Michael Greenwalt Michael Greenwalt is offline
Actually you, or the owner, should check the installation manual. Most commonly a 12 inch clearance from the vent and roof, vent and ground, and a 12 inch separation between vent and intake are required. If they went to a concentric horizontal vent termination kit they could use one hole and disregard the separation requirement. Best to check with the manufactures installation manual to determine actual clearances.
If I had two faces, would I be wearing this one?
Abraham Lincoln
Old 12-12-2007, 08:21 AM
Eric Barker's Avatar
Eric Barker Eric Barker is offline
The specifications will vary from manufacturer to manufacturer. Distances from intake to exhaust can be up to four feet. There are also specs on clearances to inside corners or other surfaces. You can't rely on a single source for this, in particular, any code reference.
Eric Barker
Barrington, IL
Old 12-13-2007, 05:46 AM
I did do some research on this prior to posting my question. Rheem's online material had the information on the location of the vents as it pertains to corners, windows and the like, but from what I could tell did not have any specifications on the seperation of the intake and exhaust. It may have been in fine print somewhere in that case I missed it. A typical termination in my area is one that has the intake with a 90 facing down and the exhaust turned up with 12" riser on it and then an outward facing 90.
Carl Eisen
West Bend, WI
Similar Threads
Plumbing vent termination Jeff Eastman Plumbing System: Home Inspection and Commercial Inspection 14 07-17-2008 06:11 PM
WH vent termination from headwall Clay White Plumbing System: Home Inspection and Commercial Inspection 16 11-01-2007 03:57 PM
Vent termination Dave Gilstrap Plumbing System: Home Inspection and Commercial Inspection 2 10-19-2007 09:13 AM
Roof sidewall intersection David Banks Roofing System: Home Inspection and Commercial Inspection 8 09-29-2007 06:25 AM
Could not locate dryer vent termination M Kelekci Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 9 09-23-2007 07:48 AM
vB.Sponsors
Ad Management by RedTyger
