11-20-2007, 04:57 PM
Venting questions
The single wall vent pipe from the WH to furnace was about 5.5 ft off floor and may present a burn danger. It is right next to the washer/dryer and I nearly bumped my head on it (164 degrees from my IR therm) I could see someone easily touching it and getting a severe burn - is there a specifc code reference for that?
Also I am not thrilled with the Tee (backdraft to WH), but I cannot find anything to not alllow it.
And finally, plastic duct for return air?
Comments?
11-20-2007, 05:10 PM
Re: Venting questions
Comments?
Rick,
I sure hope JP don't see that.
Billy J. Stephens HI Service
11-20-2007, 07:14 PM
I don't install it, I just report it!
My main question is abouty the hot vent pipe being in an area where someone can - almost did (me) - and probably will get burned. It's going in as a safety issue, but I was looking for some specific reference if available.
11-20-2007, 07:47 PM
Rick,
If you feel it's a safety issue you do not need any specific reference.Common sense will do.
Picture1: Does not appear proper up slope of 1/4 inch per foot.
If this single wall vent goes through the attic it is prohibited.
Picture 2: Plastic Duct is not Rated as Supply Air Duct.
Reason: 2 added
11-20-2007, 08:10 PM
That stuff is not really rated for any use, but they can make it and sell it, in fact you are even allowed to buy it ... just not allowed to use it for any known use I can think of.
11-21-2007, 07:13 AM
Just to be obnoxious, I would point out that some humidifier manufacturers specify the use of flexible duct, and this one's instructions clearly illustrate a plastic, not metal type.
► Desert Spring Furnace Humidifier
11-21-2007, 07:56 AM
bold is mine
Originally Posted by Michael Thomas
I don't see that they clearly illustrate plastic, and they certainly don't specify plastic in the instructions.
11-21-2007, 08:17 AM
Michael,
The flex duct is included in the kit and not the $1.99 Plastic kind.
Reason: and
11-21-2007, 08:23 AM
Thanks for hunting that down. Can't tell exactly what that material is but you are correct - it does not appear to by the cheesy white plastic duct.
11-21-2007, 04:10 PM
In Michael's defense  that flexible duct was likely drawn on a "white" page, so the flexible duct "looked" "white".
The flexible duct in Billy's post looked to be that "UL Listed" mylar foil type. Still do not know "to what" it is "UL Listed" to, but, something to consider is that most of those slinkies are made for 'positive' pressure and when being used for 'return' it would be under negative pressure, which might delaminate the flexible material and pull it off its slinky coil.
11-21-2007, 05:55 PM
Vent Picture came from Rick M's link posted above page 10 Parts List (Tech Support)
| Thread Tools |
Search this Thread |
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
| Venting Issues |
Michael Thomas |
6 |
11-18-2007 01:50 PM |
| Combustion Air venting for Direct Vent FPs |
Clay White |
Fireplaces, Chimneys and Solid Fuel Burning Appliances: Home Inspection and Commercial Inspection |
4 |
10-17-2007 04:23 PM |
| water heater venting |
Seth Hughes |
6 |
08-05-2007 09:22 AM |
| Venting for gas fireplace |
Jon mackay |
3 |
06-19-2007 06:01 AM |
| Combustion air venting location |
Jeff Eastman |
14 |
04-24-2007 07:43 PM |
