Old 12-03-2007, 11:10 AM
Furnace clearance from rear closet wall
Old 12-03-2007, 11:23 AM
Michael Thomas's Avatar
Re: Furnace clearance from rear closet wall
I would check manufacturer's instructions, can be zero.
Old 01-24-2008, 03:34 PM
max kasten max kasten is offline
The building code requires 30" on all sides see bellow
Appliances shall be accessible for inspection, service,
repair and replacement without removing permanent construction,
other appliances, or any other piping or ducts not
connected to the appliance being inspected, serviced, repaired or
replaced. A level working space at least 30 inches deep and 30
inches wide (762 mm by 762 mm) shall be provided in front of
the control side to service an appliance. Installation of room
heaters shall be permitted with at least an 18-inch (457 mm)
working space. A platform shall not be required for room heaters
Max Kasten
Building code official
Old 01-24-2008, 03:42 PM
John Arnold John Arnold is online now
Quote:
Originally Posted by max kasten View Post
The building code requires 30" on all sides see bellow ...
...A level working space at least 30 inches deep and 30
the control side to service an appliance....
I see where it says 30 inches in front. I don't see where it says 30 inches on all sides.
Similar Threads
Water heater clearance william siegel Plumbing System: Home Inspection and Commercial Inspection 4 10-06-2007 04:13 PM
Clearance for an air conditioner Kevin Luce Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 7 08-20-2007 11:41 AM
B Vent Window Clearance Jim Robinson Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 9 06-16-2007 09:11 AM
Who needs 6" of clearance for single wall Paul Kondzich Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 5 04-28-2007 07:17 PM
Propane regulator clearance Jim Luttrall Plumbing System: Home Inspection and Commercial Inspection 13 04-16-2007 08:30 AM
vB.Sponsors
Ad Management by RedTyger
