Re: Who;e Hpuse Fans and High efficiency Furnace
Annie-Laurie,
If you are referring to a furnace where an intake pipe is extended to the exterior to supply air directly to the burner, then there should be little chance of backdrafting. However, if there is a water heater inside, then there is still a potential of backdrafting.
The apostrophe troll.
