Old 04-12-2007, 01:50 PM
dan orourke dan orourke is offline
condensate drain connection
Old 04-12-2007, 02:05 PM
Eric Barker's Avatar
Eric Barker Eric Barker is offline
Re: condensate drain connection
Not proper. It is BillieBob's MO though.
And, BTW, welcome.
Eric Barker
Barrington, IL
Old 04-12-2007, 09:19 PM
Kevin VanderWarf's Avatar
Kevin VanderWarf Kevin VanderWarf is offline
The only reason I might say it's allowed is the age of the system and it's factory specs and I don't know what the code would have been then(whatever the age is).
I've seen a lot of older systems with ABS connected to PVC.
However, I would write that up and recommend 3/4 pvc.
The one thing about ABS, it's never sloped properly.
On my reports, if it's not PVC it's gotta go.
Consistency is a direct path to perfection.
Similar Threads
lead drain John Arnold Plumbing System: Home Inspection and Commercial Inspection 5 04-17-2007 04:18 PM
NM liquid Tight to EMT connection Warren Alderman Electrical Systems: Home Inspection and Commercial Inspection 7 04-07-2007 10:02 AM
vB.Sponsors
Ad Management by RedTyger
