Old 12-18-2007, 04:58 PM
william siegel's Avatar
william siegel william siegel is offline
Garage air handlers
I know this has been dicussed before, but I did a search on it and cannot find anything on this subject, jut air handlers in the attic. Does an air handler in the garage need to have a pan underneath it and does it need a secondary drain line?
File Type: jpg 742 Sw 158 Terr Pem Pines(Wynn) 028.jpg (51.6 KB, 55 views)
Bill Siegel
Florida Home Inspection Team Inc.
Home inspection
Old 12-18-2007, 05:09 PM
Rick Hurst's Avatar
Rick Hurst Rick Hurst is online now
Re: Garage air handlers
Its going to condensate like any other unit being in the attic, hall closet or in the garage, so a pan would be needed also. Yes, on the secondary drain line also.
Water leaking from the equipment could cause other damages to the structure too even being in the garage.
A float switch in the primary drain line would be more appropriate in my opinion.
Old 12-18-2007, 05:18 PM
Eric Van De Ven's Avatar
Eric Van De Ven Eric Van De Ven is offline
Quote:
Originally Posted by william siegel View Post
I know this has been discussed before, but I did a search on it and cannot find anything on this subject, jut air handlers in the attic. Does an air handler in the garage need to have a pan underneath it and does it need a secondary drain line?
Not to mention a smoke alarm.
Eric Van De Ven Magnum Inspections Inc. (954) 340-6615
www.magnuminspections.com
Old 12-18-2007, 05:49 PM
Bill,
And just like in the attic (talking about 'new' homes here - say late 2005 and newer) have the same (ugh!) exceptions to those requirements.
Is there a cut off switch in the secondary or primary condensate lines?
And 26 gage duct or fire damper at the wall. (Also depending on year of construction.)
Old 12-18-2007, 05:54 PM
House built in 1995
"Is there a cut off switch in the secondary or primary condensate lines?"
Not that I could see.
Bill Siegel
  #6 (permalink)
Old 12-19-2007, 07:46 AM
Scott Patterson's Avatar
I thought a secondary pan was needed only if it was over a finished area of the home and the condensation could cause damage to the home if it leaked.
Scott Patterson
  #7 (permalink)
Old 12-19-2007, 07:58 AM
Rick Hurst's Avatar
Scott,
If it were to leak on the floor it could run back towards the drywall and therefore cause damages. I know most would think that the floor should be sloped to allow it to drain but most of the garages I encounter do not slope at the front part of the garage.
I've seen WH leak being in the garage and cause damages to the structure, so why not this same set up with this air handler?
  #8 (permalink)
Old 12-19-2007, 09:19 AM
Quote:
Scott,
From the 2006 IRC (which does not help Bill on his installation)
- M1411.3 Condensate disposal. Condensate from all cooling coils or evaporators shall be conveyed from the drain pan outlet to an approved place of disposal. Condensate shall not discharge into a street, alley or other areas where it would cause a nuisance.
- - M1411.3.1 Auxiliary and secondary drain systems. In addition to the requirements of Section M1411.3, a secondary drain or auxiliary drain pan shall be required for each cooling or evaporator coil where damage to any building components will occur as a result of overflow from the equipment drain pan or stoppage in the condensate drain piping. (remaining text of this section not posted as it was not applicable to this question)
Not withstanding, of course, all of the exceptions which allow NOT having an auxiliary pan under the air hander even in an attic.
Nonetheless, though, M1411.3.1 refers back to M1411.3, and M1411.3 states "Condensate shall not discharge into a street, alley or other areas where it would cause a nuisance.", and overflowing condensate is still "condensate" and is still not allowed to "cause a nuisance".
  #9 (permalink)
Old 12-19-2007, 09:51 AM
Quote:
Scott,
Okie Dokie! That is what I get for thinking!
Scott Patterson
Similar Threads
garage floor william siegel Exterior Systems: Home Inspection and Commercial Inspection 7 10-24-2007 02:12 PM
Attached garage Clay E White Building Interior: Home Inspection and Commercial Inspection 2 08-04-2007 07:59 PM
Insulation over garage M Kelekci Attic Areas: Home Inspection and Commercial Inspection 14 07-23-2007 07:46 PM
Garage Vents Charles Smith Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 8 07-11-2007 10:45 AM
garage quandry Erik Elwood Building Envelope: Home Inspection and Commercial Inspection 7 06-09-2007 12:52 PM
vB.Sponsors
Ad Management by RedTyger
