Old 01-12-2008, 05:22 PM
Michael Thomas's Avatar
Refrigerant line protection at studs and top plates
Does the IRC require refrigeration lines to be protected where they pass through studs and top plates (similar to the protection required for NM wiring)?
Old 01-12-2008, 06:10 PM
James Duffin James Duffin is offline
Re: Refrigerant line protection at studs and top plates
IRC Section M1308.2 says yes.
Old 01-12-2008, 06:50 PM
To add to James 'yes' ... the protection if closer to that required for plumbing pipes than for NM cable.
Old 01-13-2008, 07:11 AM
Thanks as always to you both.
Similar Threads
Buried Refrigerant Line and Run Distance ? Rick Hurst Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 5 10-31-2008 07:18 PM
External DWV need UV protection? Robert Alexander Plumbing System: Home Inspection and Commercial Inspection 22 10-25-2008 12:00 PM
FRT or Equivalent Protection Eric Smith Attic Areas: Home Inspection and Commercial Inspection 6 07-16-2007 10:04 AM
Greetings from Protection Inspection in Nashville, TN David Edens Introductions By New Members 1 07-05-2007 01:51 PM
Electrical Cables contacting truss plates Jeff Eastman Electrical Systems: Home Inspection and Commercial Inspection 7 06-09-2007 07:51 AM
vB.Sponsors
Ad Management by RedTyger
