Old 04-14-2007, 10:15 PM
Paul Kondzich Paul Kondzich is offline
Condensate leak at furnace exhaust
I had a new construction today. 92% condensating furnace in crawl space. My question is right at the furnace exhaust there was a water leak, and about 5 feet away where the PVC pipe turns verticle to go up towards roof another leak. I also checked attic where pipe penetrates roof and it was dry. I could not tell for sure but it looked as if the water was on the outside of pipe not coming from inside of pipe. Any ideas why there could be water in the exhaust pipe. The condensate drain was on other side of furnace going to a pump.
Old 04-14-2007, 11:23 PM
Bob Harper's Avatar
Bob Harper Bob Harper is online now
Re: Condensate leak at furnace exhaust
If you suspect moisture on the outside of the pipe, just hold a sheet of notebook paper against it. You'll see the blue lines blur and form a water spot.
A leak in a Cat. IV vent could be fatal as these are under positive vent pressure. If this is flue gas condensate, it should be very acidic. If there are any drops, you could pat some baking soda to them and see if it fizzies or not. Also, look at the puddles on the concrete floor. Condensate will eat up concrete. Remember your 8th grade chemistry: acid + base > salt + water
A tech needs to inspect this unit and test with a combustion analyzer for CO spillage. With the vent running, you can use gas leak soap bubbles or even Windex or my trusty chemical smoke puffer.
HTH
Old 04-15-2007, 09:08 AM
Brian E Kelly Brian E Kelly is offline
If I saw the pictures correctly, the pipe does not seem to be glued. Or at least not primed prior to the glue. If this is the case the preasure from the fan may allow the condensate to escape out the fittings. My guess is that the gluing and priming were not done properly muchless at all.
Well thats my 2 cents.
Brian Kelly
Kelly Home Inspections
Similar Threads
Furnace vent Jeff Eastman Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 3 04-14-2007 07:28 PM
condensate drain connection dan orourke Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 2 04-12-2007 08:19 PM
That dread Exhaust Vent - Texas gang RobertSmith Built-In Appliances and Systems: Home Inspection and Commercial Inspection 8 04-09-2007 07:58 PM
vB.Sponsors
Ad Management by RedTyger
