Old 04-18-2007, 05:22 AM
Jim Dull
Posts: n/a
Disconnected Wire
This wire is connected to the AC unit and runs along the low pressure line (which obiously need to be reinsulated) but is not connected to anything else. Anyone know why?
Also, the refrigerant lines run along the ground for about 8 feet before entering the house.
Home inspection
Old 04-18-2007, 05:33 AM
Rick Cantrell Rick Cantrell is offline
Re: Disconnected Wire
Most likely the cable from the thermostat to the compressor relay.
Rick Cantrell
Old 04-18-2007, 06:52 AM
If it is connected, like Rick said, the thermostat wire.
If it is not connected, it 'was' the thermostat wire and has been replaced with a new wire for whatever reasons.
Old 04-18-2007, 06:53 AM
I forgot to ask ... what is that rubber cord looking wire for or to?
Old 04-18-2007, 09:06 AM
Jim Dull
Posts: n/a
Thanks guys. Jerry, see the attached. For your information, this is a foreclosure and just about everything is missing. Appliances, light fixtures, receptacle and switch covers, etc.
  #6 (permalink)
Old 04-18-2007, 09:31 AM
Jim,
You are referring to the wire on the right side of the gas meter, not the one on the left side, right?
The one on the right side is another view of the thermostat wire in your previous photo. The one on the left side is a tracer wire for the gas piping underground, it does not get connected to anything.
Similar Threads
Glowing wire nut Phillip Stojanik Electrical Systems: Home Inspection and Commercial Inspection 7 10-04-2007 05:09 AM
2 Wire Load Side Fuse Panel Michael Thomas Electrical Systems: Home Inspection and Commercial Inspection 2 04-12-2007 03:22 PM
vB.Sponsors
Ad Management by RedTyger
