Old 02-21-2008, 07:39 PM
Anthony Alderman's Avatar
Anthony Alderman Anthony Alderman is offline
Heat Pump temp defferntial
is there a specific temp deferential for a heat pump on heat cycle with out any emg heat???
"A woman is only a woman, but a good cigar is a smoke".
Kipling
www.aahomeinspectionsllc.com
Old 02-21-2008, 07:59 PM
Jim Luttrall Jim Luttrall is online now
Re: Heat Pump temp defferntial
Nope. Heat pumps operate under such a wide range of temperatures, there is no "normal" temperature split.
Now, having said that, I look for about 20 degrees as a starting place, but just because it achieves or exceeds that does not mean it is working correctly.
Mr. Inspector.net, Inc.
Allen, Texas 75002
Old 02-21-2008, 08:03 PM
Thanks Jim. The one I had today was getting about 12-14 at most. not sure whether to call it or not, for service
Kipling
Old 02-21-2008, 08:55 PM
What was the indoor return air temp?
and the outdoor temp?
Was the outdoor coil frosted?
How long had it been running?
Were both coils clean?
Allen, Texas 75002
Old 02-21-2008, 09:21 PM
What was the indoor return air temp? 64
and the outdoor temp? 38
Was the outdoor coil frosted? no
How long had it been running? over night
Were both coils clean? Yes
Kipling
  #6 (permalink)
Old 02-21-2008, 11:25 PM
Nick Ostrowski Nick Ostrowski is online now
Anthony, you'll likely get many different responses on this but I look for a differential of between 18-30 degrees in heat mode. If you were only getting a temp differential of 14 degrees tops, I would call for servicing. An exterior air temperature of 38 degrees is not so low that it should place an excessive tax on the system.
Any idea how old the system was?
  #7 (permalink)
Old 02-22-2008, 06:25 AM
2002 1.5 ton for small 3rd level
I did go ahead and call for service cause it did seem really low. I just realized I had never seen any concrete numbers before sooooo I went to the guys who know
Kipling
  #8 (permalink)
Old 02-26-2008, 09:34 AM
Kevin VanderWarf's Avatar
Kevin VanderWarf Kevin VanderWarf is offline
sorta rule of thumb but certainly logical.
If the heat pump is to perform without the strips kicking in you could expect it to produce at least 12 to 18 degrees defferntial. I think anything less than 12 and the strips would not be far from kicking in.
I have always removed the cover of the t-stat so that I can see that the first bulb only is engaged while checking the heatpump temp, then raise to engage the second bulb and look for a significant increase.
The combined stages will produce the more unpredictable temp but 100 to 130 degrees should be expected.
Consistency is a direct path to perfection.
Similar Threads
Heat Pump water heater Ron Bishop Plumbing System: Home Inspection and Commercial Inspection 2 12-20-2007 06:06 PM
"Insider" indoor heat pump Richard Moore Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 6 10-11-2007 04:00 PM
Attic temp during our heat wave ren ramsey InspectionBlues: Home Inspectors & Commercial Inspectors 15 08-15-2007 07:47 AM
Mismatched Lennox heat pump and high temp diffs Lou Collier Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 23 05-17-2007 05:26 PM
Heat Pump? David Banks Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 15 05-06-2007 02:04 PM
vB.Sponsors
Ad Management by RedTyger
