Old 02-26-2008, 06:42 AM
Ron Bishop Ron Bishop is offline
direct vent?
This indoor air handler is located in a hall closet. I did not notice any combustion air supply, but 2 PVC vents were present. I am assuming that one of them is for supply air, and that this is a direct vent system. Any thoughts?
Ron Bishop
Shasta Lake, Ca.
Old 02-26-2008, 07:05 AM
Re: direct vent?
Ron, were you able to locate the two pipes on the outside of the building? If so you can turn the unit on to see if exhaust comes out of one of the pipes. Anytime they put a unit in a closet it needs exterior combustion air for the heat side. Some municipalities will let it go if the closet has a full louvered door. By the way you say it's an air handler, so is it only providing cooling and heat is supplied by a boiler?
The other issue I see from the photo is that the 90's are DWV fittings. Ok for combustion but not generally accepted for venting. Are you sure it's not poor plumbing venting?
Good luck, Markus
847/736-9975
Markus Keller
Old 02-26-2008, 07:22 AM
Re: direct vent?
Excuse me...this is a split system, with the AC unit outsde.
Ron Bishop
Shasta Lake, Ca.
Old 02-26-2008, 07:31 AM
John Arnold John Arnold is online now
Re: direct vent?
Quote:
I think Markus was referring to the fact that you didn't mention a furnace. There is a gas furnace there, right? Not just an air handler.
Old 02-26-2008, 07:34 AM
Re: direct vent?
Correct, John
847/736-9975
Markus Keller
  #6 (permalink)
Old 02-26-2008, 07:36 AM
Re: direct vent?
A furnace is present.
Ron Bishop
Shasta Lake, Ca.
Home inspection
Similar Threads
Combustion Air venting for Direct Vent FPs Clay White Fireplaces, Chimneys and Solid Fuel Burning Appliances: Home Inspection and Commercial Inspection 4 10-17-2007 03:23 PM
Direct vent location Clay E White Fireplaces, Chimneys and Solid Fuel Burning Appliances: Home Inspection and Commercial Inspection 4 09-24-2007 06:01 AM
Gas fireplace direct vent location Jon mackay Fireplaces, Chimneys and Solid Fuel Burning Appliances: Home Inspection and Commercial Inspection 14 07-11-2007 06:16 PM
Gray PVC for direct vent furnace Jon mackay Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 0 06-08-2007 04:52 AM
LP tank near direct vent Frank Bombardiere Fireplaces, Chimneys and Solid Fuel Burning Appliances: Home Inspection and Commercial Inspection 1 05-22-2007 06:11 PM
vB.Sponsors
Ad Management by RedTyger
