Old 03-14-2008, 10:18 PM
Grant Harrod Grant Harrod is offline
Heat pump freeze-up
Louisiana home: 7-yrs. old with (International Comfort Products) heat pump and electric heat furnace in attic. I performed my inspection and visually saw a 3-4 in. band of ice on the exterior of the heat pump approximately 12-in. from the base of the unit. The temperature was 58-59 degrees and was raining at the time of inspection. I turned on the heat inside to 75 degrees and the supply registers were at 110-111 degrees, with the emergency heat on the supplys went to 133. Returns were at 70 degrees. I shut the system off so pressures could equilize and turned on the air after approx. 15-20 minutes. The supply registers were at 55-56 returns at 69-70. I did not see a problem with the system operation as I have read that heat pumps will freeze up in high humidity/rainy weather. Here's the problem: Inspection was performed on Jan. 16, 2008 and new owners moved in on the 21st of Jan., (3) days later the complete unit froze up and would not heat the home. Owner called tech and filled with freon. (2) days later the unit froze up again. Tech says they need complete new unit. They are now coming to me. I told them it was working on the day of the inspection and owners wife and son were there when I performed my systems operation and temp. checks.
"How about some input from the A/C guys. Thanks for your help in advance. Grant
Old 03-15-2008, 12:05 AM
Re: Heat pump freeze-up
Sounds like the tech does not know what he is talking about or is intentionally selling them a bill of goods.
Sounds like the defrost timer or sensor may be the culprit. Get a second opinion, and ask if the tech would have known the unit would fail (if it really has) the next week if he had done a visual inspection before it went out.
You may learn something, if so, consider it an educational expense and step up to the plate.
Even if the unit is broken, things break, an inspection is a snap shot in time of the condition of the property.
I assume the heat worked for 3 days according to your description, case closed.
There is no reason to add refrigerant unless there is a leak.
In fact, the act of adding refrigerant to a system that does not need it can damage the compressor or otherwise cause a system to malfunction.
I do have a couple of concerns with your description of the system operation.
There should not be "ice" on the exterior coil. White "frost" is OK, but clear solid ice should not be present under most circumstances (freezing rain, etc. excepted)
I would normally expect a 20 - 25 degree rise during heat pump only operation.
Your 35 degree rise on heat pump only sounds a little high, but I was not there.
Don't let the first and second stages of supplemental heat fool you into thinking the heat pump is working.
I advance the thermostat only one or two degrees above room temperature (just until the unit starts) and visually inspect the exterior unit for proper function at the same time I take TD readings, then advance the stat to bring on the supplemental.
I will leave the heat pump and supplemental on long enough for every thing to sequence on and expect a substantial TD rise above the heat pump only.
Then I shut down the supplemental with the "emergency heat" switch on the stat if it has one and check the outdoor unit again for shut down and another TD expecting a drop from the "all in" TD.
Good luck.
Mr. Inspector.net, Inc.
Allen, Texas 75002
Old 03-15-2008, 08:53 AM
Scott Patterson's Avatar
If it is icing it could also be a refrigerant leak.
I would pay to have my own tech to go and take a look at the system. Then I would compare what my tech and the owners tech said and try to figure it all out.
I'm betting on a refrigerant leak or a bad timer on the defrost cycle. You know the compressor is running as it is making ice. Now, here's another thought. The unit could have burned itself out (dead compressor) and this is now why the tech is saying it needs to be replaced.
Scott Patterson
Old 03-15-2008, 09:11 PM
Thanks guys for your feed back, I am contacting my A/C tech to have him check out the system. I don't like the idea of the new owner calling a tech then getting scammed by him. Wish I could have had my guy look first. Puts me on the spot. I still don't think I should pay for anything because the unit was working the day of the inspection and 8-days after I inspected the home. Thanks for your help, I will keep you posted.
Grant
Old 03-15-2008, 09:26 PM
  #6 (permalink)
Old 03-16-2008, 06:38 AM
David Banks David Banks is offline
Quote:
Grant
If they did any repairs or replacement without giving you notice then you should be off the hook. As long as that is in your contract.
Dave
  #7 (permalink)
Old 03-16-2008, 10:13 AM
Brandon Chew Brandon Chew is offline
Tenth Avenue Freeze-Out...
Sorry for the thread drift. Reading this thread got me humming that song.
We now return you to your regularly scheduled broadcast.
  #8 (permalink)
Old 03-17-2008, 08:35 AM
Kevin VanderWarf's Avatar
Kevin VanderWarf Kevin VanderWarf is offline
Your talking about a 3" band of ice on a heatpump, they do that and then they defrost.
If anything there might be some adjustment needed in the defrost cycle.
The cycle time is adjustable, if you had total defrost failure there would be much more ice than that.
Adjusting the freon charge may also be considered.
Step up to the plate? I dont think so, those were good temp readings.
That fact the return (or inside) temp dropped 15 degrees in 20 minutes raises other questions.
If the temp dropped 15 degrees in 20 minutes, that indicates that the unit was heating the hell out of the place before you shut it down.
As far the tech, he's wrong. From what youv'e stated, all other major components were functional.
Defrost problem at the very least, no new unit.
Consistency is a direct path to perfection.
  #9 (permalink)
Old 03-17-2008, 09:12 AM
Kevin,
Quote:
Step up to the plate? I don't think so, those were good temp readings.
If you read my original opinion, there was a big IF, in front of the step up to the plate.
IF your tech tells you that you missed a big problem, etc. then learn from it.
If not, then I agree, the temps and operation as described look pretty good.
By the way, as one of my instructors way back in the dark ages was fond of saying about the meaning of frost on a line, coil, etc. was: "the only thing that frost proves is that the line is or was below 32 degrees." In other words, it is not a diagnostic tool other than a visual confirmation that the line was cold enough to make frost. Don't get fooled into diagnosing based on a little or a lot. It is significant if you have a buildup of solid ice, not frost, which can indicate problems with clearing the coil totally during defrost.
Allen, Texas 75002
  #10 (permalink)
Old 03-17-2008, 09:39 AM
Jim,
I agree, ice vs. frost is a valid point.
What I disagree with the most is the idea that enitre unit would need to be replaced.
If he got good temp readings and all was functional, then his job as an inspector is done. That is, if the frost line was at least noted.Otherwise, diagnosing the defrost cycle or stating weather a functional system should be replaced would be clearly beyond the scope of your average inspection. Therefore, no fault should placed on the inspector in my opinion.
  #11 (permalink)
Old 03-17-2008, 12:58 PM
I agree with you Kevin, unless the second opinon guy can give you some definitive evidence (which I doubt) that the HI screwed up.
Allen, Texas 75002
  #12 (permalink)
Old 03-17-2008, 10:34 PM
I appreciate your help you guys, I got in touch with my tech today and we are going to the home on Wednesday to check it out, Thanks again for the support, thats why I joined this link.
Grant
Similar Threads
Heat Pump temp defferntial Anthony Alderman Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 7 02-26-2008 09:34 AM
Heat Pump Question Eric Shuman Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 7 02-23-2008 09:27 AM
Heat Pump water heater Ron Bishop Plumbing System: Home Inspection and Commercial Inspection 2 12-20-2007 06:06 PM
Mismatched Lennox heat pump and high temp diffs Lou Collier Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 23 05-17-2007 05:26 PM
Heat Pump? David Banks Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 15 05-06-2007 02:04 PM
vB.Sponsors
Ad Management by RedTyger
