Old 04-23-2007, 04:43 PM
Michael Vasquez Michael Vasquez is offline
Aluminum duct at the water heater
This is the first time I have seen an aluminum duct (dryer type duct) used for a gas water heater vent. Just want to make sure if this is acceptable or not before I comment on it. Thank You
Old 04-23-2007, 04:47 PM
Jerry Peck's Avatar
Re: Aluminum duct at the water heater
It is probably a listed 'vent connector'.
You should have been able to find a label on it stating it was listed for that use.
Those 'are not' allowed to go through a wall or ceiling, they are only allowed to connect the appliance to the Type B Gas Vent.
Old 04-23-2007, 04:51 PM
Thanks again Jerry
Old 04-24-2007, 03:53 PM
Bob Harper's Avatar
IFGC 503.10.1 General. A vent connector shall be made of noncombustible corrosion resistant material capable of withstanding the vent gas temperature produced by the equipment and of sufficient thickness to withstand physical damage.
NFPA 211 dittoes this but adds if corrugated, must be listed. This is due to decreased flow capacity by corrugated ducts.
I recently ran to a hardware store to get some vent connector and all they had was cheap aluminum flex, like you see with dryer vent kits. Its tag stated it was rated to 480F. I told the homeowner it was suitable for an overnight repair but that was it. This duct does Not meet the requirements for physical damage. Moreover, it comes apart really easily.
Make sure it is not a listed aluminum flex connector, which has listing stickers on it and is much more rigid and substantial than dryer vent flex.
HTH
Old 04-24-2007, 03:56 PM
Bob Harper's Avatar
I recently ran to a hardware store to get some vent connector and all they had was cheap aluminum flex, like you see with dryer vent kits. Its tag stated it was rated to 480F. I told the homeowner it was suitable for an overnight repair but that was it. This duct does Not meet the requirements for physical damage. Moreover, it comes apart really easily. It is so sloppy, it cannot hold its shape and needs much more support than rigid pipe. You need slings. If you try to screw through a "drive' into it, the flex just crushes and comes apart. Real junk. All it's good for is making robot arms for the kid's school play...
HTH
  #6 (permalink)
Old 04-24-2007, 07:19 PM
Jerry Peck's Avatar
Quote:
Bob,
Er ... did you mean to say "Make sure it is not a listed ", or "Make sure it is a listed "?
  #7 (permalink)
Old 04-25-2007, 01:19 AM
Bob Harper's Avatar
Listed means it is ok. The stiff stuff with the listing stickers is ok. The dryer vent hose is crap.
Home Inspector Essentials. The BEST prices for inspection tools.
Similar Threads
American Appliance water heater age Patrick McAvoy Plumbing System: Home Inspection and Commercial Inspection 11 04-20-2007 10:30 PM
Water Heater Location Jeff Eastman Plumbing System: Home Inspection and Commercial Inspection 2 04-14-2007 10:52 PM
Water heater Question Jeff Eastman Plumbing System: Home Inspection and Commercial Inspection 2 04-12-2007 04:29 PM
Reverse plumbing to water heater Terry Beck Plumbing System: Home Inspection and Commercial Inspection 7 04-06-2007 05:54 AM
ABS Flue Pipe on LP Water Heater Trey Humphreys Plumbing System: Home Inspection and Commercial Inspection 6 04-03-2007 02:11 PM
vB.Sponsors
Ad Management by RedTyger
